You need 3 of IRF510, they are the transistors. As usual you can get them cheaper from someone other than Radio Shack. A IRF520 would also work, there are lots of potential replacements.
MOSFETs are good parts. The RS version is a poor example, but good enough. When they are on they usually only have a couple of milliohms, which means they tend to stay cool to the touch even carrying a lot of amps. If it weren't for the static sensitivity they would be perfect. If you every try designing with them be aware they require 10V minimum to turn on completely.
Looking good from here.
I'm wrapping presents between posts.
