Hi Everyone
I would be very grateful if I could have some help I bought a Pic programmer to program the pic16f628a
this programmer has some examples with it, one example uses 6 leds which sequence through the six leds one at a time
then starts over again using notepad++ I was able to make the leds do different things by changing the ("0" and "1" in effect 1) what I would like some help with is what code could I add to the attached program that will let the leds fade instead of just turning off
thanks for all your help
john
;* VELLEMAN High-Q KIT K8048/VM111 SAMPLE SOFTWARE *
;* DEMO1: Simple Running light for testing LD1...LD5 *
;* DEMO1: Program for testing K8048/VM111 with PIC16F627! *
;* (C) VELLEMAN Components,2003 All rights reserved *
;* Hardw. Rev: P8048'1 Softw. Rev: 1.20 *
;* OSC.......: XT 4MHz Max. POWER.....: 12V DC *
W EQU H'0000'
F EQU H'0001'
;----- Register Files------------------------------------------------------
INDF EQU H'0000'
TMR0 EQU H'0001'
PCL EQU H'0002'
STATUS EQU H'0003'
FSR EQU H'0004'
PORTA EQU H'0005'
PORTB EQU H'0006'
INTCON EQU H'000B'
OPTION_REG EQU H'0081'
TRISA EQU H'0085'
TRISB EQU H'0086'
CMCON EQU H'001F'
;----- STATUS Bits --------------------------------------------------------
IRP EQU H'0007'
RP1 EQU H'0006'
RP0 EQU H'0005'
NOT_TO EQU H'0004'
NOT_PD EQU H'0003'
Z EQU H'0002'
DC EQU H'0001'
C EQU H'0000'
; RAM Definition
__MAXRAM H'01FF'
__BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
__BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
__BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
__BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
; Configuration Bits
_BODEN_ON EQU H'3FFF'
_BODEN_OFF EQU H'3FBF'
_CP_ALL EQU H'03FF'
_CP_75 EQU H'17FF'
_CP_50 EQU H'2BFF'
_CP_OFF EQU H'3FFF'
_DATA_CP_ON EQU H'3EFF'
_DATA_CP_OFF EQU H'3FFF'
_PWRTE_OFF EQU H'3FFF'
_PWRTE_ON EQU H'3FF7'
_WDT_ON EQU H'3FFF'
_WDT_OFF EQU H'3FFB'
_LVP_ON EQU H'3FFF'
_LVP_OFF EQU H'3F7F'
_MCLRE_ON EQU H'3FFF'
_MCLRE_OFF EQU H'3FDF'
_ER_OSC_CLKOUT EQU H'3FFF'
_ER_OSC_NOCLKOUT EQU H'3FFE'
_INTRC_OSC_CLKOUT EQU H'3FFD'
_INTRC_OSC_NOCLKOUT EQU H'3FFC'
_EXTCLK_OSC EQU H'3FEF'
_LP_OSC EQU H'3FEC'
_XT_OSC EQU H'3FED'
_HS_OSC EQU H'3FEE'
__CONFIG _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
; Variable Definition
TIMER1 EQU H'20' ;Used in delay routine
TIMER2 EQU H'21' ; " " "
PATERN EQU H'22' ;Pattern data for effect's
ORG 0 ;Reset vector address
GOTO RESET ;goto RESET routine when boot.
; * Example of a delay routine *
DELAY_ROUTINE MOVLW D'255' ;54 Generate approx 10mS delay at 4Mhz CLK
MOVWF TIMER2
DEL_LOOP1 MOVLW D'255' ;60
MOVWF TIMER1
DEL_LOOP2 DECFSZ TIMER1,F
GOTO DEL_LOOP2
DECFSZ TIMER2,F
GOTO DEL_LOOP1
RETLW 0
; ** RESET : main boot routine **
RESET MOVLW B'00000111' ;Disable Comparator module's
MOVWF CMCON
BSF STATUS,RP0 ;Switch to register bank 1
;Disable pull-ups
;INT on rising edge
;TMR0 to CLKOUT
;TMR0 Incr low2high trans.
;Prescaler assign to Timer0
;Prescaler rate is 1:256
MOVLW B'11010111' ;Set PIC options (See datasheet).
MOVWF OPTION_REG ;Write the OPTION register.
CLRF INTCON ;Disable interrupts
MOVLW B'11000000'
MOVWF TRISB ;RB7 & RB6 are inputs.
;RB5...RB0 are outputs.
MOVLW B'11111111' ;all RA ports are inputs
MOVWF TRISA
BCF STATUS,RP0 ;Switch Back to reg. Bank 0
CLRF PORTB
EFFECT_1 MOVLW B'00000001' ;Activate LD1 (RB0)
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00000010' ;Activate LD2 (RB1)
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00000100' ;Activate LD3 (RB2)
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00001000' ;Activate LD4 (RB3)
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00010000' ;Activate LD5 (RB4)
MOVWF PORTB
CALL DELAY_ROUTINE
MOVLW B'00100000' ;Activate LD6 (RB5)
MOVWF PORTB
CALL DELAY_ROUTINE
GOTO EFFECT_1
END
john
W EQU H'0000'
F EQU H'0001'
INDF EQU H'0000'
TMR0 EQU H'0001'
PCL EQU H'0002'
STATUS EQU H'0003'
FSR EQU H'0004'
PORTA EQU H'0005'
PORTB EQU H'0006'
INTCON EQU H'000B'
TRISA EQU H'0085'
TRISB EQU H'0086'
CMCON EQU H'001F'
IRP EQU H'0007'
RP1 EQU H'0006'
RP0 EQU H'0005'
NOT_TO EQU H'0004'
NOT_PD EQU H'0003'
Z EQU H'0002'
DC EQU H'0001'
C EQU H'0000'
; RAM Definition
__MAXRAM H'01FF'
_CP_ALL EQU H'03FF'
_CP_75 EQU H'17FF'
_CP_50 EQU H'2BFF'
_CP_OFF EQU H'3FFF'
_WDT_ON EQU H'3FFF'
_LVP_ON EQU H'3FFF'
_LP_OSC EQU H'3FEC'
_XT_OSC EQU H'3FED'
_HS_OSC EQU H'3FEE'
MOVWF TIMER2
MOVWF TIMER1
GOTO DEL_LOOP2
DECFSZ TIMER2,F
GOTO DEL_LOOP1
RETLW 0
MOVWF CMCON
;Disable pull-ups
;INT on rising edge
;TMR0 to CLKOUT
MOVLW B'11000000'
MOVWF TRISA
CLRF PORTB
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
MOVWF PORTB
CALL DELAY_ROUTINE
GOTO EFFECT_1
END
