LED example in "Using Multimeter"
Discussion in 'Feedback and Suggestions' started by alisonken1, Apr 2, 2007.
  1. alisonken1
    Apr 2, 2007
    In the example of using a multimeter to display voltage -
    Using a Voltmeter, you use the example of an LED converting light into voltage.
    From my understanding of LED's, the reason they are called LED's are the full spelling of the acronym: Light Emitting Diode. LED's convert current into light (hence, the word "Emitting" in the acronym).
    It is my understanding that Light Sensing Diode's are what you would be using to convert the light into electricity (which is what the chapter is showing - how to read voltage in a multimeter). Another option would be using a solar cell to convert light into voltage (typical solar cells are 1.5-2.0v at low milliamp rating).
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Indeed an LED can be used as a light detector. Here is another mention of an Led used as light detector . It is by no means the most efficient approach to detecting light but it will work.
    I have seen several B.E.A.M. robots that used LEDs as light sensing elements. That is mainly because LEDs are cheap and plentiful.
    hgmjr
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Isn't that essentially a photodiode?
    Dave
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Dave,
    That is my thought as well.
    I was thinking that the LEDs conductance changes as a function of the light energy rather than generating an electrical voltage out.
    hgmjr
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Which IIRC is similar to the photodiode in reverse bias.
    In response to the OP, I will have a look at the referenced section later and make more specific comments. If its a case of confusing terminology, even if the existing terminology is correct, then we can look at clearing it up.
    Dave
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Having read the article more thoroughly, I can conclude that it is infact correct and clear. Whilst there is some literal contradiction in the meaning of the name Light Emitting Diode with regards to sensing and responding to a light sourse, the experiment clearly identifies the circumstances when a diode can be used as a "light sensing diode" (in the same manner as a photodiode):
    This experiment clearly demonstrates the ranging functions and applications of LEDs, and hence the e-book article is both technically correct and clear.
    I welcome further comments on this.
    Dave
