LED Efficiency
Discussion in 'General Electronics Chat' started by Sensacell, Jun 5, 2015.
  1. Sensacell
    Jun 19, 2012
    1,183
    276
    Designing some high power LED devices with SMD RGB LEDs.
    These parts are very small (5 x 5 mm) yest dissipate large amounts of power.
    For current 0.6 A and the forward LED voltage, the part will draw about 5 electrical watts with R,G,B all on.
    From the thermal perspective, I usually assume that all the power goes to heat, a conservative approach.
    But... as these devices become more efficient, this assumption becomes inaccurate:
    The question is:
    How do I calculate how much actual power (watts) that actually radiates in the form of light?
    Total power input (VA)= radiated optical power + heat energy produced.
    The heat output will always be less than the total input power, but by how much?
  2. Bordodynov
    May 20, 2015
    670
    194
    I don't know the efficiency Xlamp.
    But usually (depending on color) 5% -40%.
    I think that, on average, 20 per cent.
  3. Sensacell
    Jun 19, 2012
    1,183
    276
    Hmmm. I need some handle on how to get a real number for this?
  4. Sonoran Desert Tortoise
    Member
    Oct 30, 2014
    53
    34
