Led Driver
Discussion in 'The Projects Forum' started by imraneesa, Feb 10, 2015.
  1. imraneesa
    Dec 18, 2014
    189
    Anybody please review this circuit and give me the suggestions. I want to drive a laser diode with vf of 3 to 3.5v and works with a constant current of 300mA.
  2. Dodgydave
    Jun 22, 2012
    5,153
    770
    Can you draw your circuit using correct symbols and not blocks, you would be better using a Lm317 as a current driver.
  3. imraneesa
    Dec 18, 2014
    189
    Lm317 need at least 3v higher than the output. My source is only 3.7v and vf of the led is 3~3.5v. So it would not work. Unless if there is a way to amplify the volts before lm317.
  4. imraneesa
    Dec 18, 2014
    189
    I will try to draw it with correct symbols asap.
  5. Dodgydave
    Jun 22, 2012
    5,153
    770
    Whatever you use as a current source,the supply voltage will have to be higher, you cant have a constant current and a constant voltage together.
  6. imraneesa
    Dec 18, 2014
    189
    Ya I know. But the lm317 will drop some voltage. So if I use 3.7v battery when it passes through lm317 it drops 2v so I will get only 1.7v which is not sufficient for laser diode. The source should be at least 6v for it to work using lm317.
  7. imraneesa
    Dec 18, 2014
    189
    Here is the circuit diagram with actual shapes.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you check out my library I have several ways to do this.
    I would do this with a transistor and a couple of diodes.
    I'll sketch something up.
  9. imraneesa
    Dec 18, 2014
    189
    How to check tour library. And is this circuit OK? Or it need changes? If need changes I will first study your library. But how to get into your library.
  10. Dodgydave
    Jun 22, 2012
    5,153
    770
    Your circuit wont work, as a TL431 has an internal reference of 2.5v, your better off supplying the led direct from the power with a transistor and diodes.
  11. imraneesa
    Dec 18, 2014
    189
    i used it to increase the voltage. it is given in datasheet that the voltage can be set from Vref (2.5v) upto 30V. Please correct me.
  12. Dodgydave
    Jun 22, 2012
    5,153
    770
    Yes, but you have to have a supply that goes with it,you cant amplify something for free!
  13. imraneesa
    Dec 18, 2014
    189
    Modified circuit. can anybody tell me the lm358 acting as comparator or it is acting like negative feedback.
  14. ScottWang
    Aug 23, 2012
    4,930
    777
    V_R4=300mA*0.33Ω=0.099V.
    The V_R1 is quite low, so the current flows through the R1,R2 and Pot also will be low, and the range of (+) input voltage should be around 0.08V~0.2V or some more range.
  15. imraneesa
    Dec 18, 2014
    189
    I did not understand.
    According to what I studied with my own self reading here and there
    the shunt regulator getting very low current due to R1 and that will be iR1= 3v/660 = 4.54mA. and due to R2 and pot the shunt regulator outputs voltage = Vref * (1+R2/Pot) = 2.5 * (1+10k/10k) = 5V.
    The current gain of d882 is 150.
    so if the current input receiving by d882 is 4.54ma. the current flow from collector to emitter is 150 times 4.54mA.
    ie. 4.54*150 = 681mA. I don't know what is the use of R3 and R4. and what is the use of lm358 there? if it is just acting as switch.
  16. ScottWang
    Aug 23, 2012
    4,930
    777
    R3 was in parallel, using it to get a lower voltage, and sometimes was used it to avoid the (+)input floating when the pin 2 of pot is disconnect.
    So if we don't care the R3, then V_pot = 3V/(R1+R2+Pot)=3V/(680Ω+20K+10K)=0.097mA=97uA.
    You can calculate the voltage of pot and the voltage of (+) input.
    Using R4 to get a voltage to comparing with the (+)input.
  17. imraneesa
    Dec 18, 2014
    189
    how much voltage will be near - pin of lm358? how to calculate the voltage near - pin. and if positive pin is more than the negative pin. the output will be 3v right?
  18. ScottWang
    Aug 23, 2012
    4,930
    777
    I just uploaded the circuit to be your reference, you may check it and modify it to suit your application.
  19. imraneesa
    Dec 18, 2014
    189
    Let me explain what I am doing. before that. I have to thank you for teaching me and taking your time for me. May God bless you.
    According to the datasheet the zener diode current is as follows:
    IR1 = 3-2.2 / 120 = 0.006666A. i.e. 6mA.
    Voltage near R1 = 0.00666 * 120 = 0.7992V
    Voltage near R2 = 0.7992V * 200 / (2000+200) = 0.7265V (I don't know how you got 0.098V)
    According to you voltage near + is 0.098V and near - is 0.099V. Since - is higher lm358 output near 1 is 0. (am I right?)
    please tell me what will be the output of lm358 in that condition. and how much voltage is going to d882 transistor base?
  20. ScottWang
    Aug 23, 2012
    4,930
    777
    If you like to calculate more details then the base of Q3 need a resistor Rb_Q3, and the C_Q3 is 300mA, and I_RbQ3 is 30mA, so the Ie_Q3 is 330mA.
    The (-) about V- = 330mA* 0.33 ohms = 0.109V.
    So the V(+) of op amp should be adjust the voltage about 0.09V~0.2V, you can over the range, but just don't small than that.
    Normally the V(+) should higher than the V(-) a little, when the V(-) big than V(+) then the output of o amp will turn to low and the Q3 will be turn off.
