LED driver
Discussion in 'General Electronics Chat' started by JohnUK21, Dec 26, 2014.
  1. JohnUK21
    Dec 23, 2014
    I want to replace the LED driver of a fitting that has a consumption of 15 w
    They gave me a driver with an output of 23-28 V with 500mA constant current
    This has an output of 11.5 to 14w. When I asked them if it is correct they said that the driver has a power factor of 0.9
    And 14w/0.9=15.5w
    So they declare the driver 15w
    I'm confused . Please someone help!
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Dont worry about the driver; worry about the LED.
    What are the LED ratings?
    LED Voltage?
    LED current?
    JohnUK21 likes this.
  3. JohnUK21
    Dec 23, 2014
    Thank you mike!!
    I have to check the led specs
    However how is the power factor related and they declare the driver 15w?
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Usually, it is the efficiency that matters; not the power factor...
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    Sounds like, "Baffle them with BS". An LED is not a reactive load, so power factor has nothing to do with it.
    PackratKing likes this.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,464
    792
    If you take power factor to indicate the difference between resistive & reactive loads, then you might get away with that.
    A string of LEDs with a limiting resistor would only draw current when the sum total of Vfs were exceeded by near the peak half-cycle - this is pretty much what common usage takes PF to mean nowadays.
    Similarly, a SMPSU only takes blips of current at the crests of the sinewave to replenish the charge on the reservoir capacitor.
    AFAIK; anything over 50W must have a PFC front end - this is usually a boost converter, on the mains bridge rectifier; the reservoir cap is replaced by a much smaller foil cap as filtering, the current pulses drawn by the boost converter more or less track the instantaneous value of the mains sinewave.
    The boost reg charges the reservoir electrolytic for the main SMPSU section - in a UK 220V unit the reservoir cap would typically be rated 450V.
    #12 likes this.
  7. #12
    Nov 30, 2010
    16,705
    7,358
    This thread seems to be about 15 watts, and if you try to use power factor to get there, you have me stumped. However, thanks for the information. I learn something almost every day here.
