LED Driver ZXLD1350 to switch a 1.4Amp LED
Discussion in 'The Projects Forum' started by RodneyB, Mar 10, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    654
    14
    I am wanting to make an LED driver for a 10Watt LED. My supply voltage is 24 Volts.
    The details of the LED can be found at http://www.mantech.co.za/datasheets/products/PWD3AH1.pdf
    In the past I have used the ZXLD1350 LED driver this does not have the correct current rating, Is it possible to use a MOSFET like the IRLR2905 to be switched by the driver.
    I am not sure how this would control the current to the LED.
    Many thanks
    Rodney
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    You would need a PWM input to the FET to change brightness. You could try using the LX output of the LED driver if you used a smaller LED as a dummy load on the driver chip just to get the LX output if you really want to use that chip.
  3. RodneyB
    Apr 28, 2012
    654
    14
    Thanks for the reply,
    I don't have to use this chip, basically I am looking for a driver suitable for a 10 Watt LED. I am open to any suggestions and advice
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You might want to look at the AL8807.
    That can drive leds with 1.3 A directly.
    Bertus
