I for my sins purchased several LED down lighters for a project I was working on from a company in China.
Within 10 minutes all the drivers had failed, the surface mount LED driver and various other components literally fell off the boards. Another example of cheap junk.
I now find myself in the position where I have to replace the lights or repair the drivers. Having had a failure already I personally would like to build the driver where I can heaven forbid it happens again replace or repair the driver.
I have since purchased the ZXLD1350 LED driver a SMD device and all the associated equipment.
According to the information on the Lamp I need to build a driver that drives the LEDs at 350mA from a power supply between DC13-36 Volts. Therefore I decided on a 24 Volt DC power supply into the LED driver.
There is a circuit diagram on the data sheet showing a typical application circuit. (Data sheet attached)
I have managed to purchase all the components bar the inductor. In Zimbabwe we do not have a supplier for SMD components and the suppliers in South Africa do not have a 47 Uh SMD inductor. Are there alternatives that can be used As I cant seem to find a suitable detail about what the purpose of the inductor is for and how to calculate the required size.
These lamps will not have a dimmer attached ever.
Many thanks
Rodney
Many thanks
Rodney
