Led driver help
Discussion in 'The Projects Forum' started by tc61, Jul 9, 2011.
  1. tc61
    Feb 11, 2009
    9
    I was wondering if someone could take a look at this LED Driver I am working with and tell me how the Control Inputs are used. They look like simple on off inputs but I don't know if they are routed to ground to be on, or you need a voltage input to trigger the on off.
    I attached the cut sheet with the diagram on it. The CTL 1, 2, 3 are what I am looking at.
    Thanks in advance
    Tim
    http://www.diodes.com/datasheets/AL3159.pdf
  2. joeyd999
    Jun 6, 2011
    2,756
    2,923
    The data sheet is quite clear. An CTL input voltage of less than 0.4V is considered a '0', and greater than 1.4V is considered a '1'. The combination of 1's and 0's determine which LEDs are on.
  3. tc61
    Feb 11, 2009
    9
    thanks for making it "Quite Clear".
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    There is a truth table on page 6. It is positive true logic.
  5. tc61
    Feb 11, 2009
    9
    What threw me off was the
    Absolute Maximum Ratings table...
    VCTL1,2,3 CTL1, CTL2, CTL3 to GND Voltage -0.3 to VIN +0.3 V
    thanks for the help guys..
    have a good weekend
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This simply means that if your inputs go lower than GND or higher than VIN that the IC will be destroyed.
    What's not obvious is that if you have a long signal path from your controlling unit to the IC, and the signals have low transition times, the inductance of the signal path and the capacitance of the IC's input pins comprises a series LC circuit that will "ring" at high frequencies. Adding resistance in the signal path at the IC's input will help to eliminate the ringing, as in the attached simulation.
    #12 and KJ6EAD like this.
  7. #12
    Nov 30, 2010
    16,671
    7,314
    Lord_Baube could have used this last week, but he never posted a drawing, so we couldn't be of much help. Keep it handy. He might come back.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
