Hello All,
I am planing to make a emergency lamp with 10 -12 white LEDs (Vf=3.2, I= 20mA) using 4 NiMH batteries (2100mAH) connected in series. Using a 555 chip in the boost mode I was able to drive the LEDs. However, since the circuit does not control the current the brightness goes down as the battery voltage drops.
Does someone know some commercial chips which can drive 10 -12 LEDs at constant current in the voltage range from 1.2 V to 4.8 V?
Thanks a lot in advance.
Gopal.
Gopal.
