LED dot matrix
Discussion in 'The Projects Forum' started by teivel, Jul 9, 2014.
  1. teivel
    Jul 9, 2014
    Hi, my purpose is to find the output of led dot matrix connected to pic16f88 using flowcode V3.6.11.53. This is the led dot matrix im using. [​IMG] I try to light up each col and row first. This is the output i found for COL0-7 [​IMG] (due to using demo version of flowcode, the outputs can be used are limited ). Output for col6 and 7 are 191 and 127. When i try to light up row0 with the output of 254 at port A and 0 [​IMG] [​IMG] Please help
  2. MrCarlos
    Jan 2, 2010
    400
    134
    Hello teivel
    It is difficult to understand your paragraphs In the midst of those gigantic pictures.
    Removing them I think this is what you say:
    This is the output i found for COL0-7 (due to using demo version of flowcode, the outputs can be used are limited ).
    Please help.
    Do You have the data sheets of the dot matrix ?
    Surely therein is described how to handle it.
    Let me take the data you mention:
    I will assume that the numbers you have are decimal.
    For column 7 You have 127.
    And to row 0 You have 254.
    127 (Dec) = 01111111 (Bin). – column 7.
    254 (Dec) = 11111110 (Bin). - row 0.
    R7 1
    R6 1
    R5 1
    R4 1
    R3 1
    R2 1
    R1 1
    R0 0
    CCC 0 1 1 1 1 1 1 1
    CCCC7 C6 C5 C4 C3 C2 C1 C0
    We need to know if to turn on a column of LED’s, must be low or high.
    consequently:
    The rows will be the other polarity.
  3. teivel
    Jul 9, 2014
    hi mrcarlos, sry for posting gigantic pic that make u difficult to read ( didnt expect it would be like this )and i missed something. whn i give output of 254 at port a and 0 at port b, the led at row0 lights up but also led in row5,6 & 7... i dont have data sheet of the dot matrix. btw , when u give output of 127 to port A , the led at row 5,6 and 7 light up together.
  4. MrCarlos
    Jan 2, 2010
    400
    134
    Hello teivel
    Apparently the matrix is damaged.
    When the Port A = 254 and Port B = 000, turn ON the rows 0, 5, 6, 7.
    When the Port A = 127 and Port B = 000, turn ON the rows 0, 5, 6, 7.
    Then rows 5, 6 and 7 never go out ?
    You can do an experiment:
    Port A = 000
    Port B = 254
    Then:
    Port A = 000
    Port B = 127
    Notify what happens to the LED matrix please.
