LED display purchase question
Discussion in 'The Projects Forum' started by Samuel Peck, May 30, 2013.
  1. Samuel Peck
    May 20, 2013
    I am pretty new to electronics, and I learned that a lot of watches use a fraction of the power that each segment of the LED display parts I ordered will use. So where can I find a small display that I can wire up as a stopwatch that will use less power?
    I'm working on a toy that will only have a stopwatch as far as electronics go, and I'm hoping to keep total size of the battery or batteries I use significantly below a AAA size, and have it be able to run for a year, so low power consumption is important to me.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Go with an LCD display for lowest power consumption.
  3. GopherT
    Nov 23, 2012
    6,303
    4,021
    Here on eBay
    it is 2 lines by 16 characters. It is set and forget - the driver on the display maintains the display until the microncontroller changes the values.
    Samuel Peck likes this.
