hi all, I dont post very often but require a little assistance.
I'm working on a lighting project which uses 2x 3mm white leds and 2x white SMD's running off a 12v power supply.
I was wondering if i could use a 470ohm potentiometer on each led/smd to allow for adjustable brightness?
The point being to adjust each led/smd to a desired light level while keeping the circuit board to an absolute minimum due to space limitations.
thanks
thanks
