As a general rule of thumb, any device's inputs (logic, opamps, whatever) should never be more than one diode drop (0.6V) above or below the device's power rails. Individual data sheets often have more restrictive limits. A common method is to add two diodes to the input, one to each rail, such that they do not conduct in normal operation (both pointed up). In your case, a single 5.1 V zener to GND is good for this.I thought the LM393 was rated to handle up to 36V -- so why is a 25V Zener too high? When you say "supply voltage" are you referring to the power supply? So would the 5.1V/5W Zener I have on hand be best?
ak
