LED Control Plz help
Discussion in 'Embedded Systems and Microcontrollers' started by desi.djay, Nov 22, 2008.
  1. desi.djay
    Nov 22, 2008
    hey
    i m doing a project on PIC18F452 and using Visual basic 6.0 to control the PIC
    in the project VB will send a Byte to the PIC through a serial port and the PIC turn on a LED with that Byte
    i have the sample of my old lab
    (LIGHT
    bsf PORTA,RA1
    bsf PORTA,RA2
    bsf PORTA,RA3
    movlw 128
    cpfseq SAVEBYTE
    bcf PORTA,RA2
    movlw 2
    bcf PORTA,RA3
    movlw 5
    bcf PORTA,RA1
    return)
    so could u guys help me figure out to turn on a LED PORTA RA1 with one byte and. then turn it of with a different byte
    and turn of POTRA,RA2 with a different byte. and so on... with assembly language or MikroBasic or MikroC.
    plz help. me figure out this.
    thanx.. :(
  2. gvr_p
    Nov 5, 2008
    6
    read the byte in received buffer and send it to the portA. The on/off sequence can be manupulated in VB on PC and send it to controller.
  3. Alberto
    Nov 7, 2008
    169
    36
    One byte is composed of 8 bits so you can control up to 8 leds! send 0 to turn them all off send 255 to turn them all on.
    1 led 1 on - all the other off
    2 led 2 on - all the other off
    4 led 3 on - all the other off
    8 led 4 on - all the other off
    16 led 5 on - all the other off
    32 led 6 on - all the other off
    64 led 7 on - all the other off
    128 led 8 on - all the other off
    With cobination number you can control all the 8 leds.
    B0 var Byte
    T9600 con 2
    Led var PortA.1
    NoByte:
    Toggle Led
    Serin portA.0,T9600,500,NoByte,[B0]
    PortB=B0
    goto NoByte
    The above code in basic need to be translated in your mikrobasic (but it should not be too different).
    Connect serial Rx to PortA0
    Connect a led via 330 ohms resistor to portA.1
    Connect 8 leds via 330 ohms resistor for each led to the IO of portB (one for each pin of 8 IO port)
    Send a byte via your PC and the leds should show up.
    Alberto
  4. desi.djay
    Nov 22, 2008
    i did this code on mikro C but dont work..
    int x = 200 ; // Code recieved from Computer
    setup()
    USART_init(19200); // initialize USART module
    // (8 bit, 19200 baud rate, no parity bit...)
    // Configure ports as OUTPUT
    TRISA = 0 ;
    TRISB = 0 ;
    // Initiallize ports
    PORTA.F0 = 1 ;
    PORTA.F1 = 0 ;
    PORTA.F2 = 0 ;
    PORTA.F3 = 1 ;
    PORTA.F4 = 0 ;
    void main() {
    //setup board
    setup();
    // Infinite Loop - continuosly run while powered on
    do {
    //if ( USART_Data_Ready() ) // if data is received
    // x = USART_Read() ; // read the received data
    switch(x)
    case (1):
    PORTA.A1 = 1 ;
    PORTA.A2 = 0 ;
    PORTA.A3 = 0 ;
    break;
    case (2):
    PORTA.A1 = 0 ;
    PORTA.A2 = 1 ;
    PORTA.A3 = 0 ;
    break;
    case (10):
    PORTB.A1 = 0 ;
    PORTB.A2 = 0 ;
    PORTC.A3 = 1 ;
    break;
    } while (1); //end do->while
  5. Alberto
    Nov 7, 2008
    169
    36
    I can't help you with mikroC. The only suggestion is slow down the baud rate. Set the port at a low value at the begining than when the system works, you can increase the speed till the system works .
    Alberto
  6. desi.djay
    Nov 22, 2008
    thanx alberto . ...
    i tried all i could with. mikro c but no luck so im going with assembly language cuz i can get it to at least talk pc and turn on one light with the code i have on my first post. if u kno any thing assembly and could help i would really appreciate it.
    thanx
  7. Alberto
    Nov 7, 2008
    169
    36
    Can you tell me which is the frequency (in MHz) of the quartz or resonator of your circuit ?
    Your pic is a 40 pins ?
    Are you using a max232 for the serial connection to your PC or a simple resistor
    Alberto
  8. desi.djay
    Nov 22, 2008
    yes its a RS232 serial connection
    same as this pic and circuit board http://www.picbook.com/
    it has a 10Mhz maximum oscillator speed
    4 independent timers
    17 interrupt sources
    and the PIC pins
    Total Pins are 40
    and I/O pins 33
    I/O PORTs 5
    1536 Byte ram
    16384 program memory 16bit word
