LED constant current source scheme
Discussion in 'The Projects Forum' started by kaushizcute, Feb 16, 2012.
  1. kaushizcute
    Feb 16, 2012
    24
  2. abeychandran
    Feb 7, 2012
    17
    120ohm each
  3. kaushizcute
    Feb 16, 2012
    24
    How did you calculate?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Rsense will have 1.25VDC across it. The LM317 can not do anything else. So Rsense is the programming resistor for the current. The transistor is a simple switch in this mode, allowing Rsense to be the current feed back for the LM317. If the current goes to zero due to an open LED the transistor circuit opens, that leg is switched out of the circuit, and that Rsense in not part of the LM317 current programming.
    So the formula is ILED = 1.25V / Rsense
    It is similar to the base LM317 operation.
    I tend towards these kinds of circuits myself.
    It has the advantage of extremely low insertion with good regulation. The circuit can drop as little as 0.2V and still regulate well.
  5. John P
    Oct 14, 2008
    1,639
    225
    I think for .02 amps/leg, you want a 68 ohm resistor. But try it and see what the current is.
    The interesting difference between the two circuits is that in the one from ON Semiconductor, the LM317 regulates the current, and in Bill Marsden's one, the transistors do it.
  6. crutschow
    Mar 14, 2008
    13,523
    3,390
    One disadvantage of current mirrors is that you waste current through the LM317 leg of the mirror. But that's likely only of concern if the circuit is battery operated.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    You can reduce the current in the LM317 leg by running the current mirros "unbalanced" by adjusting the resistor values in the emitters. You can run 10 mA in the 317 leg and run higher value in the LED strings just by reducing their emitter resistors. There is no law that says those currents all have to be equal.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    The advantage of the onsemi circuit is that if one string opens, the other strings will run at essentially the same current as before. The disadvantage is that all strings need to have the same number and types of LEDs. Otherwise, currents will be different in different strings. In fact, if the forward voltages of each string are not identical, the currents will be different. This is per simulation.
    The advantage of your circuit is that the number of diodes in each string can be different, and currents will still be equal. The disadvantage is that if one string opens, the current in the other strings will drop by about 20% (again per simulation).
  9. Ron H
    Apr 14, 2005
    7,050
    657
    But the temperature coefficient of led current will increase by a small amount - probably not an issue in most cases.
    Alternately, you can also put LEDs in series with the LM317 if the supply voltage will permit it.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    True, slight difference there. You can adjust the amount of resistor in the emitter to make that effect negligible.
  11. kaushizcute
    Feb 16, 2012
    24
  12. Ron H
    Apr 14, 2005
    7,050
    657
    No, because the collector current is much lower than the specs on the datasheet. Vce(sat) will be on the order of tens of millivolts - pretty much insignificant relative to 1.25V.
    The collector current of each transistor is nominally equal to Iadj of the LM317, divided by the number of transistors.
    To ensure transistor saturation, you should set Ib≈Ic/10.
    Iadj=100uA max, 50uA typical. If you use Iadj=100uA, and have two transistors (Ic=50uA each), then the base current should be Ib=Ic/10=50uA/10=5uA.
    Ib=(1.25V-Vbe)/Rb. Using Vbe=0.6V,
    Rb=(1.25-0.6)/5uA
    Rb=130k
    This value is non-critical. You can use any value between 10k and 130k, and it should work just fine.
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Which brings us to the formula I showed. The transistor is a simple on/off switch, as I explained.
