LED connect to Transistor And gate circuit bright all time.
Discussion in 'General Electronics Chat' started by mmc01, Jul 21, 2014.
  1. mmc01
    Jul 27, 2010
    6
    I connect LDR and PIR sensor to input of Transistor And gate circuit and connect 4 LED 12V 1W to output . But LED is bright all time. when have no input from both sensor LED is little bright. So, I pull out input from LDR. when somebody pass PIR sensor it's more bright . And If have input from both sensor it's most bright. I want only ON/OFF LED not want little bright. I want to set LED output hight (12V) when input from LDR and PIR sensor is hight only. I'm not sure can it use with opamp comparator. how to fix it.
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi mm,
    Is your circuit complete.?? R9 looks incorrectly connected?
    Also the value of R1.?
    E
  3. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Your LDR circuit has no positive voltage supply.
  4. shakilabanu
    Member
    Jul 8, 2014
    44
    There are clearly multiple mistakes with this schematic, and purely accidental if this circuit is doing anything close to what you are aiming for... you need to relook the schematic.
  5. BobTPH
    Jun 5, 2013
    806
    121
    There is no power to the PIR sensor as drawn.
    Bob
