LED confusion
RodneyB
Joined Apr 28, 2012
697
I am at my wits end I built a Blue LED spot light using as per the attaché diagram.
I ran a 24 volt supply to a regulator which dropped the voltage from 24 to 13.9 volts It is a 6 amp supply @13.9 Volts regulator.
for 3 days solid the light was on and then for no reason that I know the LED's stopped working
PLEASE can some one lell me what I am doing wrong!
JingleJoe
Joined Jul 23, 2011
186
Your circuit seems sound, just did a few calculations which I'm sure you did to arrive at that resistor value :)
Have you tested the LEDs individually out of circuit? have you done the standard fault finding test: check the input and check the output and see if it's what you expect. The input in this case may be your 24V or 13.9V regulated voltage, the output would be the voltage accross each LED.
ScottWang
Joined Aug 23, 2012
7,409
Do you know how are the V/I of LED?
Assuming that the V_LED = 3V.
3v x 4 = 12V
13.9V - 12V = 1.9V
I = 1.9V/47Ω=40mA.
If the V_LED = 12V, V_R = 24V - 12V = 12V.
The R should be like this:
R =12V/40mA = 300 Ω
If using 80% of 40mA = 32mA
Then R=12V/32mA=375Ω, you may using 390Ω.
If V_LED isn't not 3V, then you can calculate the value as above.
wayneh
Joined Sep 9, 2010
17,498
It's unlikely the LEDs are the problem. Start at the wall socket and work towards the LEDs, not the other way around.
bance
Joined Aug 11, 2012
315
If you haven't got a heat sink on the regulator, I would think that is where the problem is. You're dropping lots of voltage across it, and that goes in heat loss (power dissipation)
HTH Steve
mcgyvr
Joined Oct 15, 2009
5,394
just ditch the regulator..and recalculate the resistors for 24V..
more in each series string will help with resistor wattage..
