led colour temperature
Discussion in 'General Electronics Chat' started by chrissyp, Oct 7, 2012.
  1. chrissyp
    Thread Starter Active Member
    Aug 25, 2008
    82
    10
    Hi
    I have no experience of using RGB led's .I have lots of experience of using white leds(doped blue leds) for lighting ,but most of the time they need amber filters to make them pleasing to view .Am i right in saying that the colour temperature of an RGB led could be set to an infinite amount of colour temperatures
    to alleviate the need for filters,and are they as bright as the white's
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends, I'm not sure how color temperature is really measured. It is like a color TV, and can make the eye see every color, but it is still only 3 colors spectrally.
    The reason I mention it is color temperature is actually at the spectrum it claims to be. Again though, I'm not sure.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  4. MrChips
    Oct 2, 2009
    12,635
    3,453
    The colour of an incandescent lamp is dependent on its temperature. That is where the concept of colour temperature comes into play.
    Hence you are correct. By controlling the intensity of red, green and blue light emitted from RGB leds you can create an infinite number of colours. Hence you do not need filters for proper colour balance. Think of the range, clarity and true rendition of colours on your computer or TV screen.
  5. chrissyp
    Aug 25, 2008
    82
    10
    Thanks for the inputs, i think my interest in the possibility of the idea working will lead me to getting some RGB's and doing some experiments .Having a lighting system that is infinitely adjustable for the user could be progress as everybody has a differing view of what is a pleasing colour or brightness for lighting ,maybe it could even have a light sensitive feedback circuit to adjust the light level dependant on the reflected light from surfaces around it.
