hi
i'm french student so i think that my english would clear
so i'm riting right now because i've problem
i'm working on a project i have to do a CLOCK on a Matrix LED
so to do hour second minutes ..... no problem i use the DCF77 signal
the hard part is to control the Matrix led i use a "3216 Bicolor LED 5mm Dot Matrix Display Info Board" from sure electronic
http://www.sure-electronics.net/download/DE-DP14211_Ver1.1_EN.pdf
in this they a microcontroller HT1632 led driver
http://www.holtek.com/pdf/consumer/1632v120.pdf
so i think that i understand how to initialize the HT1632 in VHDL but i don't understand how to initialize the 4 components in the DE-DP14211, and after that how to chose one of the componet
i must use a piso code but i don't how to do this code help me please
and i don't understand how to write something on the led matrix in VHDL because it's adress and how to say that we must to turn on 1 led ??
so if someone have solution for me it's cool
thank you very much
thank you very much
