Hi all,
I have some questions about LEDs connected in parallel.
I know I should not connect them in parallel (with only one limiting resistor; and I am not doing that in practice ).
I am just trying to correctly understand some behavior.
I uploaded two images of the circuit to be able to descirbe my issue.
In both images there is the same circuit; the only difference is that in one of them the S1 switch is turned on.
The specified Vf of both LEDs is ~1.7V and we assume they are identical in characteristics.
The current is limited throungh the 1K resistor.
The multimeter shows the voltage drop accros the LEDs, the ammeters show the current running through the LEDs and the total current (the bottom one).
When S1 is off the current flows through one LED and when S1 is turned on the current flows through both LEDs (in parallel).
I understand that when S1 is turned on, and the diodes are in parallel the Vf will decrease because now the current running throught the LEDs is lower (LEDs have identical characterstics) as shown by the meters.
What I do not understand is why , when S1 is turned on the total current is a little higher compared to the total current of when S1 is turned off.
Shouldn't the total current be the same in both cases (and when in parallel it will split between the LEDs), since it is limited only by the 1K resistor? Why does it behave this way?
What causes the total current to increase a little?
The circuit is simulated in Circuit Maker but the same behavior can be tested with the segments of a multiplexed 2 digit 7 segment LED display.
In this example the difference is low but when tested with a multidigit LED display the difference was a couple of milliamperes (depending on how many digits were turned on at the same time).
I am trying to understand what is the cause of this.
Thank you ,
Buzai
Thank you ,
Buzai
