It keeps coming up, for for a 25 position sequencer this is the simplest solution. You could use a shift register, but it would take about 1.5X the chips. The cost of the 4017 is very low too (as well as being very available), and it can be expanded pretty much indefinitely. I've seen other designs. Parts availability is the only reason I don't go with Wookie's suggested driver too. IMO DIPs are harder to work with than transistors, especially on PCBs, the base resistors allow for easier routing.
For 10 outputs nothing beats the 4017, it is the simplest solution.
As for the random start up Wookie mentioned, this could be handled with a pulse on reset, which could be done with a simple RC circuit. I'm glad he mentioned it though, because it is so easy to deal with and design for.
OK, I'll come up with a new design, and make a PCB layout for it. When I do it will be on its own thread, and I'll add it to the LED article as a resource, probably a addendum.
