LED bulb Disection
Discussion in 'General Electronics Chat' started by Nathan Hale, Jan 10, 2016.
  1. Nathan Hale
    Thread Starter Active Member
    Oct 28, 2011
    125
    Hello folks, Hope all is well with everyone.
    I bought an LED bulb this past summer. The bulb burned out last week and i opened it up , curious to know how an LED bulb looked like inside. Could you guys please let me know what those tiny yellow rectangles area?
    The ones lying down flat have markings beside them that say "D1, D2,D3 ..."
    The ones vertical have markings that say DV1,DV2.....etc..
    thank you for your replies.
  2. blocco a spirale
    Jun 18, 2008
    1,457
    369
    Surprisingly, those yellow rectangles are LEDs; did you expect to find something else in an LED bulb?
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Yup, they're LEDs. Most LED bulbs have at least a one year warranty; some of mine are 5 years.
  4. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    D stands for Diode, so those are LEDs, of course. The yellowish tint is to counteract the natural bluish tinge of the LED to make a warmer light. My guess is that the DV stands for a Vertically mounted LED. Notice how everything is set up to carry heat away from the LED. If you were to look deeper into the base of the bulb, the electronics to supply the proper current to the LEDs should be in there.
    I'm curious - what brand of bulb was it, if you remember? We have yet to burn out a single LED bulb after about 2 years of use. I'm starting to see bargain LED bulbs now - pack of 6, 60W equivalent FEIT LED bulbs for $12 at Home Depot. But I wonder if the newer ones are poorly made. The original compact fluorescent bulbs lasted forever. We still have one from 1990 that has been in continuous use. Once CFL bulbs became mainstream and cheap, they started burning out after just a year or two.
  5. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    I see 3 of the vertical LEDs missing in the picture. Could it be just one or more fell off? Maybe you could fix the bulb if you soldered the loose ones back on?
  6. Nathan Hale
    Oct 28, 2011
    125
    it was this led bulb....
    http://www.feit.com/led-lamps/performance/performance_led/performance_led/a19/bpom60-830-led
  7. Nathan Hale
    Oct 28, 2011
    125
    yes u r correct. some of the leds came off while disassembling the bulb. and the electronics inside the bulb! oh boy! it almost looks like a small micro controller or something!
  8. RichardO
    May 4, 2013
    1,335
    429
    This LED lamp is dimmable so the control has to be complex. :(
  9. hp1729
    Nov 23, 2015
    2,085
    232
    How did it fail? All lights out or just a few? All lights out sounds like a controller problem. The LEDs didn't fail. The driver did.
