bountyhunter
- Joined Sep 7, 2009
- 2,512
You will also find it's useless. The Vf of a diode (from which resistance would be calculated):If you look at my previous posts, I pointed out that I was assuming constant temperature. I am aware that, in practice, it could be dangerous due to the heavy reliance of Vf on temperature, but beyond that everything I have said, I think you'll find, is correct.
1) varies widely from diode to diode
2) varies with current
3) varies with junction temp
Using it to make any kind of design calculation is pure lunacy. It's a useless parameter. And, as stated, driving from any voltage source will almost guarantee device failure due to thermal runaway. No upside there.
