LED brake/tail light question from a noob
Discussion in 'The Projects Forum' started by bblevins34, Aug 14, 2011.
Thread Status:
Not open for further replies.
  1. bblevins34
    Aug 14, 2011
    This is my first post here and I have to say that this forum is very impressive. I have learned so much searching the old post. I am building a brake/tail light for my motorcycle very similar to one I found in an older post but still have one question.
    In the following schematic he is using the brake light wire and the running light wire to power the LED's. The running light wire is passing through a diode and the brake light wire is not. When the brakes are applied will the runing light wire still be sending power to the LED's? If so does this cause a problem? Sorry for the ignorance I just do not know. Thanks in advance for any help.
  2. bblevins34
    Aug 14, 2011
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just as well, automotive topics are banned as part of the Terms Of Service (ToS) at AAC. If you have any questions about LEDs and such don't link them to automotive functions. We have a link somewhere that recommends some other forums that can help when it concerns automotive.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I have removed the schematic that I posted in that topic.
    We no longer support discussions on "automotive modification" topics, as there is simply too much risk involved for those attempting such things. Even experienced, degreed automotive engineers make mistakes that regularly cause accidents. A comparatively inexperienced hobbyist would be far more likely to make mistakes than improvements.
    I urge you to not attempt the modification; keep your lights just like they were as delivered from the dealer. If you'd like to experiment, do so on the workbench, but not on your vehicle.
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
