led bjt design
Discussion in 'Homework Help' started by skusku, Sep 18, 2012.
  1. skusku
    Thread Starter Active Member
    Aug 9, 2009
    70
    Circuit - http://i49.tinypic.com/mt5lqo.jpg
    Boylestad example - http://i45.tinypic.com/20jpta9.jpg
    So the circuit is what i quickly drew as the question states.
    "The led is to have a forward current of approx 10mA. Vcc=9V, Vf= 1.6V, Vb=7V and Q1 has hfe(min)=100. Take Vbe =0.7V
    Find suitable resistor values for R1 and R2.
    What i've done is to say:
    Ib=Ic/hfe=10mA/100=1mA [current is the same for series right?]
    R1=(Vb-Vbe)/Ib= 6300 ohm
    then
    R2=(Vcc-Vf)/Ic = 740 ohm
    Okay so my circuit is very similar to the example from boylestad I have found. Is my calculations correct? For resistor R2 I have followed the book. But in the book they just use the voltage over Rc as Vcc. Is this not supposed to be Vcc-Vce? I cant seem to find any other calculations to get Vce...
  2. Ron H
    Apr 14, 2005
    7,050
    657
    If you look at the Vce(sat) specs of almost any BJT, you will find that they are specified for Ib=Ic/10. This is called "forced beta", and it is necessary because the beta of a transistor in saturation is much less than it is when Vce is, say, 10V.
    Boylestad has probably never had a real job designing circuits.
    See the attachment.
  3. skusku
    Aug 9, 2009
    70
    I saw a graph somewhere from a textbook that when Vce is in saturation mode the voltage varies from between 0V and 0.7 (Vbe).
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Saturation occurs when both junctions (base-emitter and base-collector) are forward biased.
