LED as power indicator
Discussion in 'General Electronics Chat' started by Skubby SkinnyChubby, Jul 13, 2015.
  1. Skubby SkinnyChubby
    Jun 19, 2015
    25
    i want my LED to light up when the power supply is on, so question is i can design the circuit( image attached)
    supply voltage is 24V, and is there any problem doing this?
      File size:
      13.9 KB
      26
  2. DickCappels
    Aug 21, 2008
    2,749
    665
    It should be fine if the current, or more directly, power is within the LED's specs. Also make sure you use a resistor rated at 1.3 times its power dissipation or more.
    Skubby SkinnyChubby likes this.
  3. ScottWang
    Aug 23, 2012
    4,924
    777
    If the led is rating at 2V/20mA, and considering the brightness and usage life, I will recommended that you should use it about 16 mA is better, so the resistor will be as 1K+360Ω or 1K+390Ω and the current will be as 16.2 mA or 15.8 mA.
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    For battery-powered equipment, where the additional battery drain of the LED indicator subtracts from the useful battery life, you might consider a self-flashing LED, which has lower total current demands. Also, I have operated Red "ultra-bright", high-efficiency LEDs on as little as 500uA (not near 20mA as Scott suggests), and they are still bright enough to be seen in direct sunlight as a power ON indicator.
    Do an experiment; the LED current only needs to be whatever it takes for you to see the indicator...
  5. wayneh
    Sep 9, 2010
    12,368
    3,224
    I often set my indicator LEDs to just 5mA or so. It's plenty. Flashing would be even better.
  6. ISB123
    May 21, 2014
    1,240
    531
    Get a blinker LED (LED Indication) and pick a resistor which is going to limit it to low current like 10mA.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    You can also get ultra efficient LEDs that give a useable indication at only 2mA.
    Skubby SkinnyChubby and ISB123 like this.
  8. ScottWang
    Aug 23, 2012
    4,924
    777
    What's your suggestion for the circuit and current?
  9. wayneh
    Sep 9, 2010
    12,368
    3,224
    Me? I would likely use the resistor current limiter the TS showed in #1, just using a higher ohms resistor to get the current in the 1-5mA range. If I had a flashing LED and I cared a LOT about current draw, I'd use that.
    If I really needed to limit power, I'd look at a 555 flasher with a duty cycle of, say, just 1%. (I assume a normal flashing LED has a higher duty cycle.) A 1ms flash every one second or so, that sort of thing. Of course it would have to be a low power 555.
  10. ScottWang
    Aug 23, 2012
    4,924
    777
    As you suggested that as 555 and 1% duty cycle, how is the current (mA)?
  11. wayneh
    Sep 9, 2010
    12,368
    3,224
    This feels like a hijack of the TS's thread, but see here.
    cmartinez likes this.
  12. ScottWang
    Aug 23, 2012
    4,924
    777
    I don't think that is hijack, you just given another idea and I'm trying to make it clearly.
