Hi All,
My project requires an array of 12 LEDs in parallel in one branch.
Spacing is very tight (picture a light wand but with a very narrow diameter) so I really don't have the space for a current limiting resistor next to the LEDs. Series is not really an option given that I would then have to supply 3.5Vx12 (or maybe that's the best thing i can do?)
I could place a constant current driver/circuit but:
a) I am not sure it would work given that the leds are in parallel and I can fit only 2 wires to supply the LEDs (i.e. can run a wire to the pins)
b) did not find anything suitable for a 12 LED array.
c) some of the ICs I looked at still had a ballast resistor.
My LEDs are white, 3.5V, 20mA, 100mW so nothing too powerful
What are my options? This will be connected to a power supply so I dont have limitations in that sense.
Not worry about the individual characteristics of the LEDs (they are all the same aside from probable manifacture discrepancies) and just run the array with a single resistor (bad) or some limiting circuit?
Use a driver (suggestions pls) and try to fit a resistor for each LED?
Other Ideas?
All of the above are my assumptions so if anything is wrong please feel free to point it out
Thanks a lot.
Antonio
Other Ideas?
Thanks a lot.
Antonio
