LED Array Problems
Discussion in 'The Projects Forum' started by Protactinium, Nov 28, 2011.
  1. Protactinium
    Nov 28, 2011
    I am fairly new to electronics and I attempted to build an LED array to attach it to a timing circuit.
    However after building the array and trying to attach it to the 12V power source directly to test it, and none of the leds worked. Its 36 leds in 4 parrel circuits with resistors. When I used an LED out of the same bag to test the timing circuit everything seem to function properly.
    I honestly have no idea what is wrong with the array so can someone please give me advice on how to troubleshoot it in order for me to identify my problem. I own an multimeter but thats all the diagnostic tools I have.
    Thank in advance!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, we really need to see how you wired it up, and the manufacturer's specifications on the LEDs.
    What is your intended application? What is the "timing circuit"?
    Post a schematic image; it needs to be complete.
  3. Protactinium
    Nov 28, 2011
    I am trying to make a flashing LED.
    The LED array is 9 leds with a resistor with 4 parrel circuits.
    R-Led-Led-Led-Led-Led-Led-Led-Led-Led
    12 Volt
    Its kinda ghetto schematic. This is what I used to bench test it, and no leds turned on. ~ is for
    But I am just curious if there is any kind of tests I can run in order to tell why none of the leds are ligting up. IE run a voltage test in order to tell if the circuit is running.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Every LED drops a specific voltage, referred to as Vf. The sum of the Vf in a chain must be less than the power supply voltage. You are showing 9 LEDs per chain, where 3 is the usual maximum allowable.
    A tutorial...
    LEDs, 555s, Flashers, and Light Chasers
    Read Chapters 1 and the first ½ of chapter 2.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It helps a lot if you compose your ASCII schematic using Notepad with Courier New as the font (monospaced), and copy/paste it in here with [ CODE] and [ /CODE] blocks around it to preserve the formatting.
    Code ( (Unknown Language)):
    1.    R-Led-Led-Led-Led-Led-Led-Led-Led-Led
    2.    |                                   |
    3.    R-Led-Led-Led-Led-Led-Led-Led-Led-Led
    4.    |                                   |
    5.    R-Led-Led-Led-Led-Led-Led-Led-Led-Led
    6.    |                                   |
    7.    R-Led-Led-Led-Led-Led-Led-Led-Led-Led
    8.    |                                   |
    9.    +                                   -
    10.                  12 Volt
    You undoubtedly have attempted to place too many LEDs in series.
    1) You say 12v is your supply voltage. Subtract .75v from that.
    2) Divide the remainder by the typical Vf of the LEDs at the rated current. You should have been provided that information when you bought the LEDs. If not, you will have to measure them using a constant current circuit to find out what the Vf is.
    3) Take the integer of the result of 11.25/Vf_LED. That is the maximum number of LEDs of the type you are using that you can operate in series.
    4) Subtract the result of 3) multiplied by the LED_Vf from your supply voltage.
    5) Calculate the resistor required by the result of 4) divided by the desired LED current. Use a standard value greater than or equal to that result.
    What color and current rating are the LEDs?
