LED array layout verification, and questions
Discussion in 'The Projects Forum' started by tp724, Jul 27, 2015.
  1. tp724
    Jul 27, 2015
    Hi Folks,
    I'm new to electronics and electronic projects. Below is a crude schematic I made in Excel. I used Excel so I could check the math easily.
    Q1: Are my calcs correct?
    Q2: How much power does the 75 Ohm resistor consume? 0.02 Amps?
    Q3: What is the total power consumer per series (3 LEDs and one resistor)?
    Q4: What is the total power consumed for the entire LED array?
    If you could show me the math, then I could learn a little something in the process.
    Thanks All.
  2. djsfantasi
    Apr 11, 2010
    2,900
    870
    Current is constant in a series circuit, like exists in each branch of the parallel circuits. In an LED circuit, an LED is a current limiting circuit, and your calculations are correct (Q1).
    (Q2) Power is not expressed in Amps; power is expressed in Watts. To calculate power, use the equation P=VI. Per your calculations, there are 1.5 volts across the resistor, carrying 0.02 amps of current.
    Watts = 1.5 V * 0.02 amps = 0.03 W​
    (Q3) Per series, we have 12 volts at 0.02 amps.
    Watts = 12 V * 0.02 A = 0.24 W​
    (Q4) You have four identical series. Each series draws 0.24 Watts. Multiply that by 4 and you get...?
  3. tp724
    Jul 27, 2015
  4. tp724
    Jul 27, 2015
    Fantastic. Thank you for the review and explanation. I'm picking things up a little at a time. Your reply helped a lot.
