LED advice
Discussion in 'The Projects Forum' started by irozak, May 6, 2015.
  1. irozak
    Apr 3, 2015
    I want to install a "door open" light for the shed some distance away. There is existing cabling and I found a spare pair of (cat5 type) wires so I've connected them to a magnetic switch on the door.
    At the other end of the wire I'm getting 28.5 ohms resistance when the door opens (switch closes).
    I have a 16v power supply that I can tap in to.
    What type of led, resistor, etc do I need to complete the job?
  2. blocco a spirale
    Jun 18, 2008
    1,460
    370
    If this is just a door open indicator you can use a 1k 1/2W resistor and an LED with a forward current in the 10 to 20mA range, i.e. any small, low power LED.
  3. irozak
    Apr 3, 2015
