led 240v bulb failure
Status
Not open for further replies.
debe
Joined Sep 21, 2010
1,390
LED 240V BULB.JPG LED DRY JOINT.JPG LED.1.JPG LED.3.JPG LED.4.JPG LED.5.JPG LED.6.JPG This LED bulb is only about 8 mths old & started flickering so I decided to see why. On opening it up I find the electronics is set in a grey rubbery material. On dismanteling it I discover 2 dry joints, very similar to what I find in SMPS. Ive never had this trouble with the realy cheep Ebay Chinese ones as they use resistors to set the current, not an electronic module. Just posting this as an information exercise.
Marley
Joined Apr 4, 2016
502
I have my doubts about some of these LED lamps. I've just started using some at home.
Not only the crappy power supply but this is an 11W lamp! Where is that heat dissipated? Where is the heatsink?
LEDs that run hot have a very limited life. The heat won't help the electrolytics either.
LEDs can have a life measured in 25000 to 50000 hours. Not here!
bertus
Joined Apr 5, 2008
22,278
This thread violates the ToS.
Both the leds to mains and transformerless powersupply will apply.
Bertus
Status
