least square line fit
Discussion in 'Math' started by samjesse, Oct 26, 2011.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    I have 79 observation which are increasing in value, it suppose to give a positive slop but I get a negative one (-0.00279).
    y = a * bx
    where x is 1 to 79
    I rechecked my work many times over but not able to find out why I am getting a negative "b".
    Pls. help.
    thx
    1 121.1745
    2 121.181
    3 121.1985
    4 121.2245
    5 121.253
    6 121.2775
    7 121.268
    8 121.279
    9 121.315
    10 121.3505
    11 121.3475
    12 121.3615
    13 121.409
    14 121.4445
    15 121.419
    16 121.393
    17 121.407
    18 121.4355
    19 121.4575
    20 121.4745
    21 121.4905
    22 121.5205
    23 121.5405
    24 121.534
    25 121.515
    26 121.4995
    27 121.478
    28 121.4665
    29 121.48
    30 121.515
    31 121.5265
    32 121.5315
    33 121.5495
    34 121.5085
    35 121.5375
    36 121.5895
    37 121.6065
    38 121.596
    39 121.5805
    40 121.5865
    41 121.559
    42 121.5395
    43 121.553
    44 121.574
    45 121.582
    46 121.585
    47 121.5895
    48 121.605
    49 121.615
    50 121.6155
    51 121.6405
    52 121.675
    53 121.6925
    54 121.6845
    55 121.657
    56 121.645
    57 121.654
    58 121.6555
    59 121.646
    60 121.638
    61 121.6445
    62 121.635
    63 121.6505
    64 121.6565
    65 121.653
    66 121.668
    67 121.6865
    68 121.6685
    69 121.6635
    70 121.673
    71 121.6865
    72 121.6855
    73 121.6885
    74 121.686
    75 121.712
    76 121.7495
    77 121.7605
    78 121.796
    79 121.8515
  2. justtrying
    Mar 9, 2011
    329
    396
  3. samjesse
    Sep 14, 2008
    202
    a is the constant
    b is the slop
    I am sure the formula as written in the below code is correct.
    Code ( (Unknown Language)):
    1.
    2.       a = ((sumY * sumX2) - (sumX * sumXY))/((n * sumX2) - MathPow(sumX,2));
    3.       b = ((n*sumXY) - (sumX*sumY)) / ((n*sumX2) - MathPow(sumX,2));
    4.
    5.
    it works good till n gets larger than some value then it fails.
    it is time series data thus n are sequential numbers 1 to 79 in this case.
  4. justtrying
    Mar 9, 2011
    329
    396
    I think you made a mistake in your calculations. I had originally obtained same value, but I used wrong sum in the formula - be careful what your x and y are. It is confusing since number of data points is same as the x. I think what I got now is correct - slope is 1.81. Check out the excel sheet...
  5. samjesse
    Sep 14, 2008
    202
    Sorry, I could not open the file you posted.
    here is my work, could you please tell me where I went wrong.
    thx
    1.
    2.
    3.       double sumY = 0.0;
    4.       double sumXY = 0.0;
    5.
    6.       int sumX = n*(n+1)/2;  //--- sum of consecutive integers.
    7.       int sumX2 = n*(n+1)*(2*n+1) / 6;   //--- sum of squares of above.
    8.       for( ushort i = 0; i < n; i++)
    9.       {
    10.          double Y = gets calculated here;
    11.          sumY += Y;
    12.          sumXY += ((i+1) * Y);
    13.       }
    14.       a = ((sumY * sumX2) - (sumX * sumXY))/((n * sumX2) - MathPow(sumX,2));
    15.       b = ((n*sumXY) - (sumX*sumY)) / ((n*sumX2) - MathPow(sumX,2));
    16.
    17.
    18.
    19.
    20.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    You must be doing something wrong. My results to a straight line y = mx + c gives me nothing like what you are getting.
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    Here's the regression I get with a script I wrote a number of years ago:
    1.
    2.
    3. ANOVA Table
    4.
    5. Source of
    6. Variation                   SS          df                MS
    7. --------------------------------------------------------------
    8. Regression      SSR =      1.54318       1  MSR =      1.54318
    9. Error           SSE =      0.20356      77  MSE =   0.00264364
    10. --------------------------------------------------------------
    11. Total          SSTO =      1.74674      78
    12.
    13. Adjusted R^2 =  88.19
    14.          R^2 =  88.35
    15.
    16. F statistic with df=(1,77) = 583.7
    17.
    18. Covariance matrix:
    19. [[  1.36e-04  -2.57e-06]
    20.  [ -2.57e-06   6.44e-08]]
    21.
    22. Model parameters:    Estimate        StdDev    100*StdDev/Est
    23.     b0                121.298       0.01168              0.01
    24.     b1             0.00612904     0.0002537              4.14
    25.
    26. Residuals = Res:
    27.                 Y         Yhat          Res    100*Res/Y
    28.    1        121.2        121.3        -0.13        -0.11
    29.    2        121.2        121.3      -0.1297        -0.11
    30.    3        121.2        121.3      -0.1183        -0.10
    31.    4        121.2        121.3     -0.09844        -0.08
    32.    5        121.3        121.3     -0.07607        -0.06
    33.    6        121.3        121.3     -0.05769        -0.05
    34.    7        121.3        121.3     -0.07332        -0.06
    35.    8        121.3        121.3     -0.06845        -0.06
    36.    9        121.3        121.4     -0.03858        -0.03
    37.   10        121.4        121.4    -0.009211        -0.01
    38.   11        121.3        121.4     -0.01834        -0.02
    39.   12        121.4        121.4     -0.01047        -0.01
    40.   13        121.4        121.4       0.0309         0.03
    41.   14        121.4        121.4      0.06027         0.05
    42.   15        121.4        121.4      0.02864         0.02
    43.   16        121.4        121.4    -0.003485        -0.00
    44.   17        121.4        121.4     0.004386         0.00
    45.   18        121.4        121.4      0.02676         0.02
    46.   19        121.5        121.4      0.04263         0.04
    47.   20        121.5        121.4       0.0535         0.04
    48.   21        121.5        121.4      0.06337         0.05
    49.   22        121.5        121.4      0.08724         0.07
    50.   23        121.5        121.4       0.1011         0.08
    51.   24        121.5        121.4      0.08848         0.07
    52.   25        121.5        121.5      0.06335         0.05
    53.   26        121.5        121.5      0.04172         0.03
    54.   27        121.5        121.5       0.0141         0.01
    55.   28        121.5        121.5    -0.003534        -0.00
    56.   29        121.5        121.5     0.003837         0.00
    57.   30        121.5        121.5      0.03271         0.03
    58.   31        121.5        121.5      0.03808         0.03
    59.   32        121.5        121.5      0.03695         0.03
    60.   33        121.5        121.5      0.04882         0.04
    61.   34        121.5        121.5     0.001692         0.00
    62.   35        121.5        121.5      0.02456         0.02
    63.   36        121.6        121.5      0.07043         0.06
    64.   37        121.6        121.5       0.0813         0.07
    65.   38        121.6        121.5      0.06468         0.05
    66.   39        121.6        121.5      0.04305         0.04
    67.   40        121.6        121.5      0.04292         0.04
    68.   41        121.6        121.5     0.009289         0.01
    69.   42        121.5        121.6     -0.01634        -0.01
    70.   43        121.6        121.6    -0.008969        -0.01
    71.   44        121.6        121.6     0.005902         0.00
    72.   45        121.6        121.6     0.007773         0.01
    73.   46        121.6        121.6     0.004643         0.00
    74.   47        121.6        121.6     0.003014         0.00
    75.   48        121.6        121.6      0.01239         0.01
    76.   49        121.6        121.6      0.01626         0.01
    77.   50        121.6        121.6      0.01063         0.01
    78.   51        121.6        121.6       0.0295         0.02
    79.   52        121.7        121.6      0.05787         0.05
    80.   53        121.7        121.6      0.06924         0.06
    81.   54        121.7        121.6      0.05511         0.05
    82.   55        121.7        121.6      0.02148         0.02
    83.   56        121.6        121.6     0.003353         0.00
    84.   57        121.7        121.6     0.006224         0.01
    85.   58        121.7        121.7     0.001595         0.00
    86.   59        121.6        121.7     -0.01403        -0.01
    87.   60        121.6        121.7     -0.02816        -0.02
    88.   61        121.6        121.7     -0.02779        -0.02
    89.   62        121.6        121.7     -0.04342        -0.04
    90.   63        121.7        121.7     -0.03405        -0.03
    91.   64        121.7        121.7     -0.03418        -0.03
    92.   65        121.7        121.7     -0.04381        -0.04
    93.   66        121.7        121.7     -0.03494        -0.03
    94.   67        121.7        121.7     -0.02257        -0.02
    95.   68        121.7        121.7      -0.0467        -0.04
    96.   69        121.7        121.7     -0.05782        -0.05
    97.   70        121.7        121.7     -0.05445        -0.04
    98.   71        121.7        121.7     -0.04708        -0.04
    99.   72        121.7        121.7     -0.05421        -0.04
    100.   73        121.7        121.7     -0.05734        -0.05
    101.   74        121.7        121.8     -0.06597        -0.05
    102.   75        121.7        121.8      -0.0461        -0.04
    103.   76        121.7        121.8     -0.01473        -0.01
    104.   77        121.8        121.8    -0.009857        -0.01
    105.   78        121.8        121.8      0.01951         0.02
    106.   79        121.9        121.8      0.06889         0.06
    107.
    108.
  8. justtrying
    Mar 9, 2011
    329
    396
    This is for Excel, I cannot help much with code as I am in the beginner stage myself. But I think there is a calculation error happening somewhere. I forgot which values got mixed up when I got the same value as you did initially. Maybe consider using different formulas?
    1.
    2.
    3.   a*79+b*780=9601,94    - a*n + b*SumXi = SumYi
    4.
    5.
    6.   a*780+b*167480=384329.5   - a*SumXi + b*SumXi^2=SumXiYi
    7.
    8.
    9.
    10.   a=103,65   (intercept)
    11.
    12.
    13.   b=1,81 (slope)
    14.    X    Y       X^2     XY
    15.
    16.   1   121,17   1   121,1745
    17.
    18.   2   121,18   4   242,362
    19.
    20.   3   121,20   9   363,5955
    21.
    22.   4   121,22   16   484,898
    23.
    24.   5   121,25   25   606,265
    25.
    26.   6   121,28   36   727,665
    27.
    28.   7   121,27   49   848,876
    29.
    30.   8   121,28   64   970,232
    31.
    32.   9   121,32   81   1091,835
    33.
    34.   10   121,35   100   1213,505
    35.
    36.   11   121,35   121   1334,823
    37.
    38.   12   121,36   144   1456,338
    39.
    40.   13   121,41   169   1578,317
    41.
    42.   14   121,44   196   1700,223
    43.
    44.   15   121,42   225   1821,285
    45.
    46.   16   121,39   256   1942,288
    47.
    48.   17   121,41   289   2063,919
    49.
    50.   18   121,44   324   2185,839
    51.
    52.   19   121,46   361   2307,693
    53.
    54.   20   121,47   400   2429,49
    55.
    56.   21   121,49   441   2551,301
    57.
    58.   22   121,52   484   2673,451
    59.
    60.   23   121,54   529   2795,432
    61.
    62.   24   121,53   576   2916,816
    63.
    64.   25   121,52   625   3037,875
    65.
    66.   26   121,50   676   3158,987
    67.
    68.   27   121,48   729   3279,906
    69.
    70.   28   121,47   784   3401,062
    71.
    72.   29   121,48   841   3522,92
    73.
    74.   30   121,52   900   3645,45
    75.
    76.   31   121,53   961   3767,322
    77.
    78.   32   121,53   1024   3889,008
    79.
    80.   33   121,55   1089   4011,134
    81.
    82.   34   121,51   1156   4131,289
    83.
    84.   35   121,54   1225   4253,813
    85.
    86.   36   121,59   1296   4377,222
    87.
    88.   37   121,61   1369   4499,441
    89.
    90.   38   121,60   1444   4620,648
    91.
    92.   39   121,58   1521   4741,64
    93.
    94.   40   121,59   1600   4863,46
    95.
    96.   41   121,56   1681   4983,919
    97.
    98.   42   121,54   1764   5104,659
    99.
    100.   43   121,55   1849   5226,779
    101.
    102.   44   121,57   1936   5349,256
    103.
    104.   45   121,58   2025   5471,19
    105.
    106.   46   121,59   2116   5592,91
    107.
    108.   47   121,59   2209   5714,707
    109.
    110.   48   121,61   2304   5837,04
    111.
    112.   49   121,62   2401   5959,135
    113.
    114.   50   121,62   2500   6080,775
    115.
    116.   51   121,64   2601   6203,666
    117.
    118.   52   121,68   2704   6327,1
    119.
    120.   53   121,69   2809   6449,703
    121.
    122.   54   121,68   2916   6570,963
    123.
    124.   55   121,66   3025   6691,135
    125.
    126.   56   121,65   3136   6812,12
    127.
    128.   57   121,65   3249   6934,278
    129.
    130.   58   121,66   3364   7056,019
    131.
    132.   59   121,65   3481   7177,114
    133.
    134.   60   121,64   3600   7298,28
    135.
    136.   61   121,64   3721   7420,315
    137.
    138.   62   121,64   3844   7541,37
    139.
    140.   63   121,65   3969   7663,982
    141.
    142.   64   121,66   4096   7786,016
    143.
    144.   65   121,65   4225   7907,445
    145.
    146.   66   121,67   4356   8030,088
    147.
    148.   67   121,69   4489   8152,996
    149.
    150.   68   121,67   4624   8273,458
    151.
    152.   69   121,66   4761   8394,782
    153.
    154.   70   121,67   4900   8517,11
    155.
    156.   71   121,69   5041   8639,742
    157.
    158.   72   121,69   5184   8761,356
    159.
    160.   73   121,69   5329   8883,261
    161.
    162.   74   121,69   5476   9004,764
    163.
    164.   75   121,71   5625   9128,4
    165.
    166.   76   121,75   5776   9252,962
    167.
    168.   77   121,76   5929   9375,559
    169.
    170.   78   121,80   6084   9500,088
    171.
    172.   79   121,85   6241   9626,269
    173.       sum   780   9 601,94   167480   384329,5
    174.
    175.
    176.
    177.
  9. samjesse
    Sep 14, 2008
    202
    you posted
    Sum of x = 780
    my excel shows it to be: 3160
    and the code
    sumX = n*(n+1)/2= 3160
    where n = 79
    i.e 79 observations numbered sequentially 1 - 79
    how did you get it to be 780?
    that is
    1 + 2 + ....+ 79= 3160
  10. justtrying
    Mar 9, 2011
    329
    396
    my bad, that does not take all data into account (only took 40 rows). It should be 3160. Than the slope comes out as 0.00613 when corrected (all other values are right). It is also the same value as you would get if you used excel to get the best fit line (excel equation is y=0.0061x+121.3).
  11. samjesse
    Sep 14, 2008
    202
    I got it fixed. thx. it was my bad. ushort data type does not go more than 65536. so I changed it to int and all is well.
