Bertus, thanks for the link!
Eetech00, I'm sure Bertus' link will explain, but how do you configure the graph like that???
HiBertus, thanks for the link!
Can you elaborate on what exactly you changed that gave Vdd at the outputs of the 4017? I labelled my supply voltage to Vdd, and this makes everything work, but my output voltages are well below Vdd.Thanks. That did it! Would never have found those parameters.
Hi waynehCan you elaborate on what exactly you changed that gave Vdd at the outputs of the 4017? I labelled my supply voltage to Vdd, and this makes everything work, but my output voltages are well below Vdd.
Hi wayneh,Yes, and I've been using that. Thanks again.
I'm using cd4000_v.lib, and I've attached the Vdd label to the positive rail of my circuit, 9.1V. This step made a big difference! But my 4017 produces outputs at ~6V.
Just now I tried adding the ".param VDD=9" statement and I also tried editing the properties of the 4017, changing SpiceLine from "VDD=5 SPEED=1.0 TRIPDT=5e-9" to "VDD=9 SPEED=1.0 TRIPDT=5e-9".
These changes seem to make no difference. The SpiceLine edit seems to disappear also, and it reverts back to Vdd=5.
That's what I thought!That should have worked.
Yup...CD4017 can't drive that much current.It's just to much current for it. It will drop 1/2 volt at only 1 ma.
In OS X on a Mac, leaving the .txt extension on it makes sure it opens in TextEdit, the default text editor, when double-clicked. I left it that way so I could snoop around inside to see what was there. I should change it back as you recommend and I certainly will if/when I post this again as part of a finished project.Otherwise, I'd rename it to CD4000_v.lib and change the include statement.
But the plots are 'stacked' vertically, so bear in mind that the Y-axis scale is shared by the plots.Its used for displaying multiple plots on the same plot pane.
