Learning LTSpice
Discussion in 'The Projects Forum' started by djsfantasi, Dec 6, 2014.
  1. djsfantasi
    Thread Starter AAC Fanatic!
    Apr 11, 2010
    2,900
    876
    Been trying to simulate a chaser circuit in LTSpice without success..
    The 1 Hz out from the 555 is working (almost; needs some tuning of the resistance). But the operation of the 4017 is not working at all. The pulses at the outputs are not going to zero and rising only partly. It also does not appear to be progressing in sequence.
    I have attached my LTSpice file. Can someone take a look at let me know where I am going south?
  2. ronv
    Nov 12, 2008
    3,393
    1,454
    Add a resistor for each LED. It won't go all the way to ground because the 4017 can't drive that much current all the way to ground.
    PS. the first one isn't connected.
  3. djsfantasi
    Apr 11, 2010
    2,900
    876
    Neither are any of the odd numbered outputs. Per design.
    Only one output is active at any time. The other LEDs are all reverse biased and current shouldn't flow; or am I missing something.
  4. ronv
    Nov 12, 2008
    3,393
    1,454
    No, sorry. The Q1 output under the diode part number.
  5. djsfantasi
    Apr 11, 2010
    2,900
    876
    There's no part Q1 nor any pin labelled such? Can you help me find what you are talking about?
  6. ronv
    Nov 12, 2008
    3,393
    1,454
    Output.
      File size:
      116.8 KB
      58
  7. eetech00
    Jun 8, 2013
    678
    116
    3Hi djsfantasi
    If you really want the CD4000 devices to use the 9v supply voltage you shown, you need to change the param vdd=5 to vdd=9 on each CD4000 device. Otherwise they will use the 5v default.
    Also, I believe the CD4017B outputs are only good for about 3-4ma each.
    eT
    djsfantasi likes this.
  8. wayneh
    Sep 9, 2010
    12,379
    3,232
    The CD4050 is sinking the LED current, and it's rated to sink enough, ~5mA at 5V and ~12mA at 12V.
    The problem is that Vdd has not been assigned. You need to add the Vdd label in LTspice.
  9. djsfantasi
    Apr 11, 2010
    2,900
    876
    OK, with individual resistors, I am getting better results. Please explain to me why, as in my last comment I did not expect this result.
    Oops, I lost the .asc file with individual resistors before each diode. Interesting, because the following simulation was done with a single resistor in the common anode connection.
    However, the waveforms from the 4017B still are not as expected. instead of the unactivated pins showing 0v, they all are showing approximately 3.6v... Also, a high output is only showing 5.5v instead of closer to 9v. Why?
    chaser2 graph.png Click here to see scope results
  10. wayneh
    Sep 9, 2010
    12,379
    3,232
    Huh, I just looked at my 4017 simulation and see that it shows ~6.6V for the "high" outputs, with Vdd=9V. Odd. The data sheet says the high output should be near Vdd .
    I speculate the voltage is being pulled down by the load. In my case that's an LED but your 4050 shouldn't load the 4017 that much?
    For what it's worth, my LED indicators are plenty bright in the actual build. My supply is 9.85V and the series resistor is 1K. The ultra bright LED with the narrow beam is nearly blinding, in fact.
  11. ronv
    Nov 12, 2008
    3,393
    1,454
    Not sure what's going on.
    You can use these: Then all you need to do is add a Vdd label to your 9 volts and the ic will use that.
  12. djsfantasi
    Apr 11, 2010
    2,900
    876
    Thanks. The models I am using from the yahoo group had vdd 0 as it's default and ALL sorts of strange behavior occurred when I set them to 9.
    The yahoo group alluded to the cd4000_v lib. It's 'sposed to be better.
  13. ronv
    Nov 12, 2008
    3,393
    1,454
    And, the asc.
  14. eetech00
    Jun 8, 2013
    678
    116
    Don't change that param, Leave as is. If you change that strange things will happen :-|
    There is another param vdd=5, change it to vdd=9
    eT
  15. djsfantasi
    Apr 11, 2010
    2,900
    876
    Thanks. That did it! Would never have found those parameters. I assumed that if I supplied 9v, it would use 9v…
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Output O1 goest to a buffer U4(CD4050) and the output of the buffer is not connected to the diode.
    Reason: should have said buffer in both sentences
  17. djsfantasi
    Apr 11, 2010
    2,900
    876
    The original post misread the output as Q1 instead of O1. Took me a post or two to figure that out. I turned off all unnecessary labeling to find the miswired LED. And as there are no inverters in the circuit, I will assume you meant the output of the buffer.
    Current pictures forthcoming.
  18. djsfantasi
    Apr 11, 2010
    2,900
    876
    Current LTSpice schematic:
    And the results of the simulation:
    Looks mumuchetter. My outputs are at 9vdc. The 555 is operating at close to 1Hz. And all outputs are working.
  19. eetech00
    Jun 8, 2013
    678
    116
    Hi djsfantasi
    See attached.
    Is this what your after?
    The graph shows the current flow thru the LED's vs time.
    eT
  20. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Perhaps a bit late.
    On the internet there are also quite a bit of tutorials for LTSpice.
    Here I have a query for you:
    ltspice tutorial
    Bertus
