Learning Intel assembly coding
Discussion in 'Embedded Systems and Microcontrollers' started by laguna92651, Oct 5, 2010.
  1. laguna92651
    Thread Starter Active Member
    Mar 29, 2008
    101
    I am in the early stages of learning Intel assembly coding, is there a free development tool available that I can use to test out an assembly program. Any other recommend sites or materials that I might use?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. shteii01
    Feb 19, 2010
    3,518
    515
  4. laguna92651
    Mar 29, 2008
    101
    Hi Thanks
    Did a quick review, it wasn't clear to me, will this tool allow me to write and debug in assembly language? It looks like it is just a high level language programming tool.
  5. shteii01
    Feb 19, 2010
    3,518
    515
    Yes, it does assembly language, has debugger too. It is complete suit.
    Here is one laboratory assignment I did for that class:
      File size:
      269.1 KB
      27
      File size:
      86.4 KB
      23
  6. laguna92651
    Mar 29, 2008
    101
    Thanks shteii01,
    I'll give it a try. Do you have any of your exercises you could loan me to work through the programming elements. I'm working my way through Intel Micropressors by Brey, it would be nice to work through some "projects". I couldn't read the jpg's you posted. The solutions would be nice also. Thanks
  7. shteii01
    Feb 19, 2010
    3,518
    515
    Same here, Brey, 8th Edition is what we used for textbook.
    The thing is, my professor pretty much lectured out of Sing/Triebel's 16-bit and 32-bit Microprocessors, half way through the course I found it in bookstore that sells used books, I did not even know that is where material was coming from until I was looking for some examples so that I could do the homework problem and found exact example that professor gave in class.
    My stuff is not really all that useful simply because once we got into PPI we used C/C++ and M$ Visual Studio.
    I can sort of muddle through assembly programming, that was good enough to get a B in the class, but I am very far from being any good in it.
  8. laguna92651
    Mar 29, 2008
    101
    Thanks for you input on the programming suite, I'll give it a try.
