Learn to build mini synthesizer - Where do I start?
Discussion in 'General Electronics Chat' started by LUISROD, Apr 14, 2016.
  1. LUISROD
    Apr 14, 2016
    Greetings to all....
    I have been an electronic musician for the past 30 years and want to build my own table-top synthesizer. For the past 20 years I have worked in metal fabrication and have designed enclosures and racks for the audio industry. As I am looking to further my education as an adult, I want to learn more about electronic technology. Can anyone point me in the right direction? I need to learn the basics.
    Thank you for listening.
    Luis
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    This is actually a hard question to answer. I could give you the stock answer and say start at the beginning with DC circuits. On the other hand given your mechanical and music background I could almost recommend taking an alternate path. Maybe the hybrid approach. Try the these two chapters from the online textbook associated with this site:
    1. http://www.allaboutcircuits.com/textbook/direct-current/chpt-1/static-electricity/
    2. http://www.allaboutcircuits.com/textbook/alternating-current/chpt-1/what-is-alternating-current-ac/
    Read a little bit of each section and feel your way through it. Ask lots of questions. The heart of what you want to get to is called a VCO (Voltage Controlled Oscillator) and it's digital equivalent the DDS (Direct Digital Synthesis) chip.
  3. LUISROD
    Apr 14, 2016
    Thank you for the quick response; I truly appreciate it! I will take your advice. Will post update soon.
    Best regards.
  4. Veracohr
    Jan 3, 2011
    559
    77
    Check out musicfromouterspace.com, they have a bunch of schematics for various analog synth modules.
    LUISROD likes this.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Enjoyed the "Hall of the Mountain King" on the synthesizer.
  6. #12
    Nov 30, 2010
    16,673
    7,320
    Start thinking in terms of functional blocks. Pre-amps, tone recovery amps, power amps, oscillators (sine waves, square, triangle, sawtooth), filters (low pass, high pass, band pass), time delays...Lots to learn.
    Sinus23 likes this.
  7. LUISROD
    Apr 14, 2016
    Thanks!
  8. Kermit2
    Feb 5, 2010
    3,849
    964
    A good first project might be to make a simple theremin.
  9. KJ6EAD
    Apr 30, 2011
    1,426
    363
  10. GopherT
    Nov 23, 2012
    6,305
    4,029
    @LUISROD
    A good first block might be to light an LED with a battery and a resistor.
    Then make an LED switch on/off using an NPN transistor as an amplifier/switch.
    Then make a 555 astable oscillator to flash an LED.
    Then add a potentiometer to control the speed of the flashing LED
    Then increase the frequency of the 555-and replace the LED with a speaker so you can hear the oscillator buzz and change with potentiometer resistance.
    Then start over and figure out exactly what is happening with each circuit (current flow, power ratings of each resistor, resistor-capacitor time constants) so you understand everything.
  11. ISB123
    May 21, 2014
    1,240
    531
    Simple ne555 organ should be the first step.
    Sinus23 likes this.
  12. Kermit2
    Feb 5, 2010
    3,849
    964
  13. Sinus23
    Member
    Sep 7, 2013
    178
    465
  14. hp1729
    Nov 23, 2015
    2,094
    232
    Before making suggestions ... where are you at in electronics now? Can you read a schematic and build a circuit from one.?
    Do you have to be an engineer? No, just follow a schematic and know one part from another. You don't need to design the whole thing to build a kit.
