Learn About Thevenin Theorem and Dependent Source Circuits
Discussion in 'General Electronics Chat' started by grahamed, Oct 9, 2015.
  1. grahamed
    Jul 23, 2012
    99
    11
    Hi
    I am not sure where to post this but.....
    The article says that Vth and Rth are 10V66 and 0R888 respectively. I get 9V and 5R33333.
    I could be wrong, I often am, but it seems hard to produce 0R888 out of 6, 8 and 10. It would seem that the lowest possible resistance, by any arrangement would be 6//8//10 = 2R66
    Plot shows circuit loaded by my value of 5R33 and output being 4V5, unloaded output (Vth) is 9V. I dare say someone will point out my error.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    If RL is R4 then
    Rth = (10Ω+6Ω)||8Ω = 16/3 = 5.33Ω and Vth = 12V*(8Ω)/(10Ω + 6Ω + 8Ω) + (1.5A*10Ω/(6Ω+8Ω+10Ω))*8Ω = 9V
    Also please show as this article.
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    And where is this dependent source ?? Because this will change everything.
  4. grahamed
    Jul 23, 2012
    99
    11
  5. grahamed
    Jul 23, 2012
    99
    11
    Am I missing the point? Is the dependent source being used solely as a method of analyzing the circuit, or what?
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    In this example author show as how to find a Vth and Rth when we have a dependent source in our circuit.
    But your circuit do not have any dependent source, I see only two independent source. Do you even know what dependent source is?
  7. grahamed
    Jul 23, 2012
    99
    11
    Probably not
  8. grahamed
    Jul 23, 2012
    99
    11
    This article seems to be about how to equate fig 2 to fig 1 and find values for Vth and Rth. No?
  9. grahamed
    Jul 23, 2012
    99
    11
    Ah is it saying the middle current source is 1.5 x Ix? I thought it said Ix = 1A5. If so Mea culpe.
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, but in the example the author used the Current-controlled current source (CCCS). And this current source delivers the current equal to 1.5 times the 6Ω (Ix) resistor current.
  11. grahamed
    Jul 23, 2012
    99
    11
    Yes definitely my error
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    Here you have a LTspice file. And notice that Vth = 10.6667
  13. grahamed
    Jul 23, 2012
    99
    11
    As I said I had definitely misunderstood. Thank you for your help.
