Leading Power Factor And Electronics
Grendel
Joined Jun 1, 2008
Our Power Factor correction takes several seconds to respond and hence the current can become leading during this time. An Electronic device gaining power from this supply with leading pf often resets and when the pf correction unit is switched off the problem does not occur. Does a leading power factor cause problems with supply to electronic devices?
