Lead Lag in a resonant circuit?
Discussion in 'General Electronics Chat' started by electronice123, Jul 3, 2010.
  1. electronice123
    Thread Starter Senior Member
    Oct 10, 2008
    304
    In a series LC circuit at resonance the inductive and capacitive reactances equal to cancel each other out. Doesen't that mean that the voltage and current are in phase with no lead or lag?
    Is there any way in which a series resonant LC circuit (operating at resonance) can have current which leads or lags the voltage?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. steveb
    Jul 3, 2008
    2,433
    469
    You basically answered your own question. The simple answer is no for the reason you gave.
    It's easiest to think in terms of the phasor representation using complex impedances. To have a phase lead or lag, the impedance needs to be complex or imaginary, but as you pointed out it is real for an LC circuit at resonance.
    So, you need to either modify the circuit so that it is not a simple series LC, or tune off the resonance peak. The bottom line is the effective impedance needs to have a nonzero imaginary component in order for current and voltage to not be in phase.
    For a series RLC circuit, the impedance is:
     Z=R + X_L + X_C = R + {\rm j} \omega L+ {{1}\over{{\rm j} \omega C}}
    where j is the square root of negative one. Remember that j=-1/j which is what allows the inductive and capacitive reactances to cancel.
  4. lmartinez
    Mar 8, 2009
    224
    6
    j= -1/j not a truth statement.:cool:
  5. steveb
    Jul 3, 2008
    2,433
    469
    DEFINITION: j is a number which when multiplied by itself equals -1
    Start with an obvious equality: j = j
    Multiply one side by -1/(-1) which equals unity: j = j * (-1)/(-1)
    Convert the -1 in the denominator to j*j using the definition of j: j = -j/(j*j)
    Note that j/j equals unity since any number divided by itself is unity (excluding 0/0): j = -1/j
    Hence, j = -1/j is a truth statement.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    The simplest definition of j is (in my opinion).
    j=\sqrt{-1}
  7. steveb
    Jul 3, 2008
    2,433
    469
    What is the alternative? Not only is it the simplest definition, but I thought it was the only definition. I'd be interested to hear of any alternatives, if they exist.
  8. lmartinez
    Mar 8, 2009
    224
    6
    I concur with the latter statement....Happy fourth of JULY..........:p
  9. steveb
    Jul 3, 2008
    2,433
    469
    So, which "former statement" do you not concur with?
    How are we helping the OP with these statements that seem to imply there is an unspoken issue?
    The definition given is exactly the one I gave. I gave a two different verbal definitions that are identical to this one. The second one was given as a preferred wording to prove the identity I gave, and which you said was wrong.
    The following responses seem to make a subtle implication that something is wrong. Even if this is not the intent, it is not helpful to the OP.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Sorry, Steve.:(
    I took this:
    out of context and read j = -j/(j*j) as being presented as the definition of j.
    I reread the post and realized that the equation was the result of the mathematical manipulation you were performing to prove the "truth statement", which I do not and did not dispute.
  11. steveb
    Jul 3, 2008
    2,433
    469
    No problem Ron. Yeah, that would be a needlessly confusing definition. :p
    I just want to make sure we aren't giving the OP the wrong message, that's all.
