Post a schematic.strange thing happens when i wire some leds in parallel. One LED worked fine to dark sensor but when i add few more LEDs to the circuit some of them lights up , some of them wont light up at all and others light less brighter than other ones.. Why such a mess happens? ;/
Even with the same color LED, you can get different brightnesses due to current hogging. LEDs of different colors will likely have different forward voltages, which will also result in current hogging.Hm... I have just tryed to put for example 5 same green LEDS in parallel and they light up all nicely, but when i change one green light to a red one and i have 1 red and 4 green, the one red glows brightly and the other 4 green LEDs glows very very bad Is this because their voltage differs?
Yes. In very round numbers, small red LEDs have a forward voltage (Vf) of around 1.8 V, while similar green LEDs come in at around 2.1 V. When connected directly in parallel, the RED LED comes on and holds the voltage across the green LEDs at a level that is too low for full brightness.Hm... I have just tryed to put for example 5 same green LEDS in parallel and they light up all nicely, but when i change one green light to a red one and i have 1 red and 4 green, the one red glows brightly and the other 4 green LEDs glows very very bad Is this because their voltage differs?
Hmmm i thought in this case the current matters I mean if i power my circuit with 4,5V battery so every LED in parallel will get 4,5Volts and with this voltage is more than enough to light any colour LED brightly.Yes. In very round numbers, small red LEDs have a forward voltage (Vf) of around 1.8 V, while similar green LEDs come in at around 2.1 V. When connected directly in parallel, the RED LED comes on and holds the voltage across the green LEDs at a level that is too low for full brightness.
ak
Hmm i didint quite get it This chart means that if i have for example 2.1 forward voltage LED it will need about 30mA to light brightly?and if i have 1,7V LED it iwll need like a 3mA?Voltage and current matter:
