LDR to MCU
Discussion in 'The Projects Forum' started by shico90, Aug 30, 2010.
  1. shico90
    Jul 22, 2010
    7
    I have a question, I'm building a robot and I want to detect if there is a light or not, only two states, I want the LDR to give me zero voltage if it is dark or 5 volt if it is light, I want that as a input to the MCU
    Can i connect it directly to the MCU without the need of ADC?
  2. debjit625
    Apr 17, 2010
    790
    186
    LDR is not a digital device ,its an analog device so the output is variable rather logical ,you need some sort of circuit to make the analog signal to a digital logic and it totaly depends on you as you will decide the logical values of light intensity.In my option if you use ADC you dont need any external circuit ,just you will be measuring the resistance of the LDR.
    Good Luck
    shico90 likes this.
  3. hobby16
    Aug 30, 2010
    30
    LDR is about > 100k in the dark and <10k with light.
    So if you make a divider with a 47k and feed an I/O pin, you can discriminate darkness from light. Use a trigger schmidt digital input if your MCU has one (on Microchip pic, it's on PortA), so you'll have better noise rejection.
    Otherwise, you can use a RC setup to do analog measument. All you need is to add a 100nF capacitor connected to 0V. Measuring the time the LDR charges C gives you the light level :
    0 count = 0
    1 set pin Out = Vcc during 1s => the LDR fully charges C
    2 set pin Out =0V during 1 ms => the LDR discharges C
    3 inc count
    4 set pin In
    5 if pin = 1 repeat from 2
    shico90 likes this.
  4. tom66
    May 9, 2009
    2,613
    214
    hobby16, in my experience, LDRs have a much wider swing; somewhere near 10 megohms in darkness and as few as 500 ohms in daylight. (I just tested it, with it against my 8W CFL it read only 150 ohms and covered up it read 20 megohms. So that's spanning over about 5 orders of magnitude.)
    To the OP (original poster): A simple circuit to do what you want would be to wire up a resistor and LDR in a voltage divider to get the sensitivity you want, then connecting the center point between to the base on a small signal NPN (like the 2N3904 or 2N2222), then connecting the collector to your MCU's supply voltage and the emitter to the digital input. This will, however, have a 'dead band' where it is neither on nor off and this could register as either state, so be careful to use this only with definite ON or OFF states.
    shico90 likes this.
  5. windoze killa
    Feb 23, 2006
    605
    24
    You could also feed that voltage divider centre point to a comparator thus avoiding the "dead zone".
    shico90 likes this.
  6. tom66
    May 9, 2009
    2,613
    214
    Some microcontrollers even have build in comparators. (Comparators still have a dead zone but it is *much* smaller compared to the NPN transistor circuit I posted.) Some even have internal voltage references, so you can avoid extra components for that.
    shico90 likes this.
  7. shico90
    Jul 22, 2010
    7
    Thank you all for yout help, That would make me use ADC to avoid any problems.
