LDR Protection
Discussion in 'General Electronics Chat' started by RodneyB, Apr 8, 2015.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    648
    14
    I have made a light sensitive switch. I have drilled the LDR into the side This works really great for a couple of days then almost oxidizes and wont work any more. How can I protect the LDR from this happening
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    get a good one, or put it behind a plastic window inside the housing out of the weather. some actually are potted in clear plastic.
    RodneyB likes this.
  3. RodneyB
    Apr 28, 2012
    648
    14
    If I covered it in clear silicon would that do the same job
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    chedck it after you coat it, some coatings block or absorb the light the ldr works on.
  5. RodneyB
    Apr 28, 2012
    648
    14
    thank you
  6. #12
    Nov 30, 2010
    16,671
    7,317
    The most common of that substance releases acetic acid (bad).
    RodneyB likes this.
  7. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    the GE Silicone-II product is acid free, found that out while doing some roofing with steel panels, panel maker said that the silicone would eat the paint of the panel, but the Silicone-II product does not have acid in it.
    w/o a nice even coat i suspect a coating like that will mess up the functionality, and, silicone will not stay nice for very long outside (wont break down but will collect dust/dirt and may fade in color). a UV stable clear epoxy would be better.
    RodneyB likes this.
  8. ian field
    Oct 27, 2012
    4,447
    791
    The cadmium in a LDR is extremely toxic, so the active surface should be at least securely coated with laquer, many manufacturers either potted them in water-clear resin, or even encapsulated them in windowed TO5 type cans.
    Some early types were even encapsulated in a glass envelope like valves.
    Cadmium poisoning causes osteoporosis and a very slow and painful death.
    RodneyB likes this.
