LDO regulator and capacitors
Discussion in 'General Electronics Chat' started by ArchillesElbow, Jun 11, 2012.
  1. ArchillesElbow
    May 2, 2012
    26
    If I am using a lithium polymer (lipoly) batter (4.2 - 3.7ish volts) as my source...into a module that needs 3.3v do I need to use a capacitor on the output side of my ldo if I am using a Mcp1701 (3.3v) low voltage regulator, or can I do without it? I need a stable 3.3v with around 250mah...
    Thanks!
  2. kubeek
    Sep 20, 2005
    4,689
    806
    Read the datasheet, if it says you need it then you need it, otherwise the regulator is likely to oscillate.
  3. ArchillesElbow
    May 2, 2012
    26
    I tried it anyway on a test circuit...the current fluctuates between 1.6 and 2.2 volts.. The output should be 3.3.. So I guess I need to put in a capacitor...
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Datasheets always have those answers spelled out.
  5. kubeek
    Sep 20, 2005
    4,689
    806
    That would be voltage fluctuates..
  6. ArchillesElbow
    May 2, 2012
    26
    Sorry meant voltage,, not current... I assume the current would fluctuate too tho,,,
  7. kubeek
    Sep 20, 2005
    4,689
    806
    Yes current would fluctuate too, but current is measured in amps and voltage in volts ;)
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    I wrote them for 25 years and most days was convinced I was the only human on earth who ever read them.:eek:
    Using the wrong capacitors causes virtually any LDO regulator to oscillate.
  9. ArchillesElbow
    May 2, 2012
    26
    I think u r right:)
  10. atferrari
    Jan 6, 2004
    2,667
    784
    Questions like the one in the OP usually come from not reading the respective datasheet.
    RTFM should be compulsory by law. Lot of posts would not see the light.
