Hi.
Please help me solve the problem with my LDO in the picture below. Thank you.
The figures above are not directly taken from simulation but it is very similar to my simulation results.Is this breadboard data or from a simulation?
I used a designed bandgap circuit to provide Vbg. It is relatively good.From where comes Vbg?
Sorry, do you mean power consumption?What powers this op amp?
I am using PMOS from TSMC0.18um.What MOSFET are you using?
I used Vin [2to 3.3V] to provide power supply for opamp.My guess (and I am guesing) is the supply on the op amp is 3V and above that the op amp output cannot rise high enough to correctly drive the FET, so that pulls the output out of regulation.
by Aaron Carman
by Jeff Child
by Duane Benson
by Jake Hertz
