LCR Parameters
Discussion in 'General Electronics Chat' started by marsy00, May 21, 2013.
  1. marsy00
    May 21, 2013
    I'm using an Agilent 4263B, and I'm trying to understand the relationship between different measurement parameters.
    I'm measuring an air core inductor and these are the results I get at 100kHz:
    Lp = 9.97 uH
    R = 0.968 X = 7.63
    |Z| = 7.689 Theta = 82.77
    When I measure Rdc I get: .087 ohms
    My first question is, why dont R and Rdc match? Z = R + jX = |Z|< theta... shouldnt Rdc = R??
    Second question: can someone explain the difference between Lp and Ls?
    Thanks.
  2. Ron H
    Apr 14, 2005
    7,050
    657
  3. marsy00
    May 21, 2013
    Nope, that's new to me
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Did you read the wiki? Do you understand it?
  5. marsy00
    May 21, 2013
    Yes, its interesting and it makes sense to me. According to the page, in copper at 100 kHz, the skin depth is 210 um and at 60 Hz its 0.8mm. My wire diameter is .9mm.
    So by my calculations:
    Rdc = .087 ohms
    R_real_100k = .968 ohms
    DC Conductance = 1/.087 = 11.236
    Skin Effect at 60 Hz relative to DC: .8/.9 = .88
    Skin Effect at 100 kHz relative to 60 Hz: .210/.8 = .236
    Conductance at 60 Hz: 11.236*.88 = 9.88
    Conductance at 100 kHz: 9.88*.236 = 2.306
    ==> Expected resistance at 100k: 1/2.306 = .433 ohms. I measured .968.
    Thoughts?
    Thanks!
  6. crutschow
    Mar 14, 2008
    13,501
    3,375
    The relationship between DC resistance and that due to the skin effect is not the simple ratio that you used. The "skin" is the distance into the surface of the wire so it forms a cylinder equal to the thickness of the skin.
    Thus for a skin depth of 0.8mm the cylinder would extend 0.8mm into the wire on all sides, which is greater than your wire radius of 0.45mm. Thus there is no significant skin effect at 60Hz for that wire's resistance.
    At higher frequencies you need to use the formula given in the "Resistance" paragraph in the Wikipedia article that Ron referenced.
