What could be the possible reasons for some parts of the LCD blown???
Set this to ON.#pragma config PWRT = OFF
* File: main.c
*Here we have adapted the code from JohninTx that is originally for 16F1787
* to our processor 18F4553
* Created on 2015/08/06, 16:57
//#include <stdio.h>
#include <stdlib.h>
#include <xc.h>
// #pragma config statements should precede project file includes.
#pragma config PLLDIV = 5 //(20MHz crystal div by 5 preescale
#pragma config CPUDIV = OSC4_PLL6 //we get 16 MHz
#pragma config FOSC = INTOSC_HS //Internal oscillator, HS oscillator used by USB (INTHS)
#pragma config USBDIV = 2 //Usb from PLL
#pragma config FCMEN = OFF // fail safe clock disabled
#pragma config IESO = OFF //oscillator switch over mode disabke
#pragma config PWRT = ON //OFF
#pragma config BOR = ON //CHANGED
#pragma config BORV=3 //ADDED
#pragma config VREGEN = ON //CHANGED
#pragma config WDT = OFF
#pragma config WDTPS = 32768
#pragma config CCP2MX = ON
#pragma config PBADEN = OFF
#pragma config LPT1OSC = OFF
#pragma config MCLRE = ON
#pragma config STVREN = ON
#pragma config LVP = OFF
#pragma config ICPRT = OFF
#pragma config XINST = OFF
#pragma config DEBUG = OFF
#pragma config WRTD = OFF
#define _XTAL_FREQ 4000000 // 4MHz for the delay function
void initIO(void)
OSCCON = 0x62; // 0110 0010 set CPU Frequency as 4 MHz Internal Oscillator
TRISD=0x00;
PORTD=0x00;
//no analog inputs on D
//---------------------IO DEFINITIONS --------------------------
// These are for the F4553
#define lcd_port LATD // write to LAT, read from PORT
// RD7-4 is the LCD 4 bit databus
#define LCD_RSout LATD2 // moved from ICSP
#define LCD_ENout LATD3
//-------------------- DISPLAY SETTINGS ---------------------
// Define some display settings. These could be defined as complete
// commands as well..
#define lcdLINE1 0x00 // where line 1 begins
#define lcdLINE2 0x40 // where line 2 begins
//--------------------- STROBE LCD ---------------------------
// Pulses E line on LCD to write
int strobeLCD(void)
LCD_ENout = 1;
__delay_us(2); // Added a little here
LCD_ENout = 0;
//--------------------- WRITE 8 BIT DATA TO LCD -----------------
// Assumes LCD is ready and RS is set to correct value
// LCD data bus is RD4-RD7
// Enable cycle time is a side effect of execution time - faster clocks
// may require a specific delay.
void writeLCD(unsigned char dat)
lcd_port &= 0x0f; // get current port, clear upper bits
lcd_port |= (dat & 0xf0); // combine w/upper nibble, leave lower same
strobeLCD();
__delay_us(1);
lcd_port |= ((dat <<4) & (0xf0)); // combine w/lower nibble, leave lower port same
strobeLCD();
__delay_ms(2); // wait for display to process
//-------------------- WRITE LCD COMMAND -------------------------
// Write cmd to LCD with RS=0
// Assumes E is low and display is NOT busy
void lcd_cmd (unsigned char cmd)
LCD_RSout = 0; // select command register
__delay_us(1);
writeLCD(cmd);
//---------------------- WRITE LCD DATA --------------------------
// Write dat to LCD with RS=1
void lcd_data (unsigned char dat)
LCD_RSout = 1; // select data register
__delay_us(1);
writeLCD(dat);
//-------------------- RESET/CONFIGURE LCD -------------------------
// Delays are generous, trim when able
void lcd_init(void)
lcd_port &= 0x0f; // clear upper bits of LCD port
lcd_port |= 0x30; // direct data to LCD DB7-4
LCD_RSout = 0;
strobeLCD(); // write 3h, wait 10ms
__delay_ms(10);
strobeLCD(); // write 3h, wait..
__delay_ms(10);
__delay_ms(10);
lcd_port |= 0x20; // direct data to LCD DB7-4
strobeLCD(); // write 2h
__delay_ms(10);
lcd_cmd(0x28); // Funciton Set: 4-bit mode - 2 line - 5x7 font.
lcd_cmd(0x0e); // DisplayON, cursor ON, blink OFF
lcd_cmd(0x06); // Automatic Increment - No Display shift.
lcd_cmd(0x80); // Address DDRAM with 0 offset 80h.
//----------------------- WRITE STRING TO LCD ---------------------
// Writes null terminated string to LCD from ROM
void lcd_WriteStr(const unsigned char *c)
while(*c != '\0'){
lcd_data(*c);
c++;
//-------------------- SETS CURSOR ANYWHERE IN DISPLAY MEMORY ---------
// Valid locations are 0-79 decimal. This doesn't check for valid location
void lcd_SetCursor(unsigned char loc)
lcd_cmd(loc | 0x80); // form and send 'set DDRAM address' cmd
//----------------- CANNED LINE COMMANDS -------------------------
// For a 2 line display
void lcd_LINE1(void)
lcd_SetCursor(lcdLINE1);
void lcd_LINE2(void)
lcd_SetCursor(lcdLINE2);
//======================= MAIN =====================================
const char spin[] = {".oOo. "};
int main(int argc, char** argv)
unsigned char i;
initIO(); // init the chip IO
__delay_ms(100); // power up delay for LCD - adjust as necessary
__delay_ms(100);
__delay_ms(100);
lcd_init(); // init the LCD
lcd_cmd(0x01);
lcd_cmd(0x80);
lcd_WriteStr("Kansai Robot-HH");
lcd_cmd(0xC0);
lcd_WriteStr("Salutes You XXX");
while(1);
/* lcd_WriteStr("Howdy there");
lcd_LINE2();
lcd_WriteStr("from TX!");
// a little active display :)
do{
for(i=0; spin[i]!= '\0'; i++){
lcd_SetCursor(lcdLINE2 + 11); // locate spinner
lcd_data(spin[i]);
__delay_ms(100);
__delay_ms(100);
// __delay_ms(200);
}while(1); // do forever
return (EXIT_SUCCESS);
void main(void)
__delay_ms(100);
__delay_ms(100);
lcd_cmd(0x80);
lcd_cmd(0xC0);
while(1);
Perhaps a small delay to wait for oscillator to get stable will help. (I haven't read the new code, so it might be a delay doing that. In that case, don't pay attention to this post.)I can't figure out why it works after RESETs and not straight away, but give it a go.
Your display has a controller and an extender - the 2ed smaller black blob. That could explain why you can write to the first 8 char in each line but the 2ed half of each line is junk - maybe you blew the extender.What could be the possible reasons for some parts of the LCD blown???
The LCD controller chip does a power up routine (where it checks the DDRAM/CGRAM) that can take up to 500ms to complete, once that's done and flagged inside the reset routine is usually less than 1ms.I have one question though. Are LCDs this delicate?? or did I just stumble into a particularly broken one???
Now it is working , everytime I RESET it it immediately shows the message but when I just turn it on (I mean when I turn on the 5V power) for a fraction of a second I can see the whole line of black squares and it scares me ... why do you think that happens? is that just initialization? why it doesnt happen on reset??
When resetting the MCU, you are doing just that. Resetting the MCU. If you disconnect the power, you reset the MCU and the LCD. The LCD needs a little more time to "boot".What is the difference between the power up and resetting the device? Will the LCD not take just as long to come up because it will need reinitialising and will also run through the code from the beginning...
No, internally usually the controller knows if the 'cold-start' flag is set/unset and will bypass that portition of the code on reboot.Once powered on there is a 300ms delay required... but that is implemented in the code. So once the MCU is reset that delay will be stepped through anyway wouldn't it?
by Jake Hertz
by Don Wilcher
by Jake Hertz
by Aaron Carman
