LCD with PIC 14pin chips
Discussion in 'Embedded Systems and Microcontrollers' started by Dalaran, Dec 7, 2009.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    I'm look for an LCD that will work with PIC16f684/688 or really any 14 pin PIC since this is what I am able to program.
    I found this one
    http://www.junun.org/MarkIII/datasheets/162A0LED.pdf
    It looks from the datasheet that when working in 4bit mode it should take 6 pins (4bit + Read/write + instruction/data register). Seems this works for what I am looking for. I am missing anything here? It will not be for any specific project but more for just playing around with and getting aquiated to LCDs.
    Will this work for me?
    Thanks.
  2. BMorse
    Sep 26, 2009
    2,675
    234
    ANY HD44780 Compatible LCD will work with 6 pins from a uc in 4 bit mode. There are tons of example LCD circuits and code on the web that are based around pic uc's...
  3. Dalaran
    Dec 3, 2009
    168
    Thanks for the quick, accurate reply.
  4. rjenkins
    Nov 6, 2005
    1,015
    69
    Don't forget the E pin, so seven in total.
