LCD to monitor output of power supply
Discussion in 'The Projects Forum' started by Bobstein, Apr 27, 2013.
  1. Bobstein
    Apr 24, 2013
    5
    I have a kit to build a bench ac/dc variable power supply. It needs to have a display to monitor output. Would I need to get a programmable LCD display for that application?
    I am very new to building electronics kits etc.
  2. #12
    Nov 30, 2010
    16,685
    7,322
    You can get the displays for about $10. Short time, somebody will pop up with a part number. What country are you in?
  3. GopherT
    Nov 23, 2012
    6,308
    4,029
    No, you can buy a panel meter for about $10.
    The meters just need a voltage divider resistor added to adjust them to a range of
    0 to 0.2 volts;
    0 to 2 volts;
    0 to 20 volts; or
    0 to 200 volts.
    Bobstein likes this.
  4. tubeguy
    Nov 3, 2012
    1,157
    197
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Search "DIGITAL PANEL METER" on EBay and you'll find many inexpensive and good looking units from China.
    Stuff from China takes 2-3 weeks to get to me here in NY USA using the default free shipping. Even custom PCB's got to me in 23 days from order to my door.
  6. GopherT
    Nov 23, 2012
    6,308
    4,029
    I was going to suggest the same thing in my post, order from China. I do it all the time. I was just put off by the whole "china" idea this afternoon, however. I made a homemade pizza and my son asked if DUTCHMAN brand mushrooms were from Pennsylvania (yes, I use canned mushrooms on my pizza). In any case, I flipped the can over to see where "America's favorite mushrooms (TM)" were canned. I was a little disturbed to find they were "Made in China".
    I will likely order parts direct from china after I am able to repress this current thought.
    ErnieM likes this.
  7. MrChips
    Oct 2, 2009
    12,633
    3,453
    Every time you buy something "Made in China" you put an American out of work. Think about it.
    Brownout likes this.
  8. RobeeJ
    Mar 19, 2013
    24
    If that were true, nobody in America would be in work. :)
  9. wayneh
    Sep 9, 2010
    12,382
    3,238
    Instead of a panel meter, I'd probably just hack one of those Centech meters you can sometimes get for free at Harbor Freight.
    I don't feel too bad about using chinese stuff if they're giving it away. Keep it coming, I say. ;)
  10. GopherT
    Nov 23, 2012
    6,308
    4,029
    That is brilliant, I haven't seen those before.
    For under $6 with test leads and all the ranges and functions - much better than a panel meter unless you are tight on space.
  11. #12
    Nov 30, 2010
    16,685
    7,322
    I did that. Be careful with the display and its connector. Difficult to get re-assembled correctly. Missing segments.
  12. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    I doubt anything like this is actually made in the USA and if it is then it's probably bought from China or Mexico and rebadged?
  13. Bobstein
    Apr 24, 2013
    5
    Wow thanks for all of the great advice & help, I appreciate it much
  14. ErnieM
    Apr 24, 2011
    7,436
    1,626
    I just got one to leave at my wife's office when I work there just so I'd have something. I paid a whole $2 for it new on sale.
  15. wayneh
    Sep 9, 2010
    12,382
    3,238
    Ha ha, yes I "plant" them all around too. One upstairs, one in the car, one on the workbench, one on the pegboard when one of the other ones breaks (none have yet), and so on. I don't think I've even had to replace a battery in one yet.
