LCD sizes
Discussion in 'General Electronics Chat' started by Dritech, Apr 4, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    Are there LCDs bigger than 20*4 ??
    Also, if I use graphic LCD, is it difficult to program when compared to normal LCDs?
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    I've seen at least one 40x4 character display (on EBay I believe) so there are some out there. That particular device lacked a backlight which makes it not so useful.
    A graphic display is just that: you need to set each and every pixel as you want it. It knows nothing about letter shapes so you must draw every letter. I use done once and it took some time to create the code library to run it.
    Microchip does give away such a library that works very well with the color graphic displays, even implementing buttons and such for touch screen displays.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. Dritech
    Sep 21, 2011
    756
    5
    Thanks for your replies.
    Actually I was looking for an LCD with more lines, maybe a 6 line LCD. Are there such products in the market?
  5. spinnaker
    Oct 29, 2009
    5,062
    1,160
